Lets' see...
Discussion in 'The Garage' started by UseYourBlinker, Mar 31, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Lets\' see...
    I pulled the stock manifolds off yesterday check for crack's (none found) I place new manifold gasket's in. Start up the K5 exhaust leak is still there. Sounds a bit better but still noticable. I 've replaced the lead donuts, and added manifold gaskets. The only other thing it could be is the EFE valve ($100).. then my dad brings home the horse trailer and the trailer brakes don't work. Propably put in about 6 or 7 hours of work in this weekend,and still none of the things worked on work. Makes you go hhhhmmmmm....The beauty of being a K5 owner.
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    Re: Lets\' see...
    you tried a premium gasket?
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Re: Lets\' see...
    Eric, I can resolve any leaks you have coming from the manifold to heads if you bring me the manifolds to resurface. After they are resurfaced reinstall them WITHOUT gaskets and use STAR WASHERS instead of lock washers or the lock tabs and they will not leak anymore. From the factory they never had gaskets, only the aftermarket companies have come up with gaskets due to warpage over the years. Since they will be resurfaced flat again NO GASKETS NEEDED.
  4. UseYourBlinker
    Jun 7, 2000
    11,117
    Re: Lets\' see...
    I think about t Scott. How much does it cost to get done? Man pulling those air inlet lines off the header was a bitch of a job.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Re: Lets\' see...
    I bead blast the manifolds then resurface them both for $80.00. You will not have anymore leaks from the manifold to head.
  6. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Re: Lets\' see...
    Hmmm,sounds like a guarantee..../forums/images/icons/wink.gif
