Let's talk 10 bolt tech once again boys and girls...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bubba Ray Boudreaux, Nov 2, 2002.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Let\'s talk 10 bolt tech once again boys and girls...
    First off, if I get any "get a 14B" comments, you'll be banished to a lifetime of shame and misery as Hillary Clinton's love slave.
    Now on to the topic. Just a few questions. First, if the c-clips don't fall out, snapring pliers? Second, will a gov-lock in a 3.08 geared rearend work for 3.73? And next item, after I get the axles out, take off the bearing caps and I will be able to take out the carrier? And lastly, '85 and '88 10 bolts, everything should be interchangable, right?
    Now on to some commentary. Those Gov-Locks, look kind of dinky, don't they. Oh well, doesn't matter since this a spare.....Thank you and goodnight.
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Re: Let\'s talk 10 bolt tech once again boys and girls...
    Dont know about the C-Clips, The carrier should be a direct change over. Yes, just pull off the bearing caps to get the diff out and make sure you mark them! and make sure you remeber where the shims go, that way it will be a heck of a lot easier to set up when you get ready to put it in the other rear end. Only thing that might be different is the axle shaft spline counts, just check that before you start throwin everything together.
  3. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I don't know if you caught it, I'll be taking the 3.08 gear off and installing the 3.73 on this gov-loc.
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Who cares,STFU and git a 14 bolt.
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,387
    E-town baby!
    Once the cross shaft is out push the axle inwards and if the C clip doesn't fall out use a screwdriver to help it out. It's not under tension like a snap ring or anything like that. Then pull the axle shafts out.
    I am pretty sure the 3.08 carrier is the same for the 3.73's. I think the carrier break is at 4.10 and down. The first year for 30 spline shafts was 89 so both your diffs would have 28 spline shafts...so no trouble there. As Zcarczar said stamp the bearing caps so you can orient them exactly how they were. I usually mark the upper part of the caps with one dot using a center punch and two dots on the other side. To make it idiot proof I make similar marks on the housing itself inboard of the bolt circle for the cover. The marks don't need to be super deep...just enough that you can find em again.
    I don't think you should get a 14 bolt...
    I'd say a 2.5 ton Rockwell would be better/forums/images/graemlins/grin.gif
    They are more aerodynamic than 14 bolts...
    Rene
  6. zcarczar
    Feb 10, 2002
    2,495
    I remembered that C-Clips fall out pretty easy when the Gov-Loc gernades itself, dont ask me how I know this.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I just don't get the whole 10 bolt thing when it easy to swap in a __ ____ __ /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  8. zcarczar
    Feb 10, 2002
    2,495
    Well Paul we dont need the big heavy 14 bolts, we are high speed desert guys. There is no need for over building things in the unsprung wieght department because it just makes things handle a lot worse. Plus look at the MOO Blazer, it was running 1/2 ton stuff on 37's.
  9. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    You're just jealous since I don't have to worry about breaking, I have a spare. BWAHAHAHAHAHAAHHA. Wonder if I can build me a rack in the back to carry a spare rearend?
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Thanks Rene. I worked on them with screwdrivers and they weren't coming......
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    get a 14 bolt...
    and shave the hell out of it, then shave it down to 6 lug then never worry bout weight or strength.
    oh, yeah. they should come out. get a SMALL set of pliers an grab them. the c clips that is
    carrier break is 4.10 you will be fine.
    all parts from those years are interchangeable.
    i got a 14 bolt for CHEAp!!
    grant
  12. tRustyK5
    Jul 23, 2000
    36,180
    1,387
    E-town baby!
    You should convert to IFS and IRS and get rid of all that unnecessary unsprung weight /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/grin.gif
    Oh wait, Honda already makes a CRV... /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    Just messing with the <font color="orange">"Z" car czar</font color> /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif
    Rene
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Like the others said.....
    STFU and get a 14 FF! /forums/images/graemlins/rolleyes.gif
    But if thats not big enough, dont get the 2.5 ton Rockwell.....go bigger!!! Get the 5 ton Rockwell instead!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  14. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Anything bigger than a 5 ton Rockwell?
  15. Grim-Reaper
    7,385
    Atlanta
    hehehe Scrap the 10 and go to a 12. 12 runs bigger bearings in the pinion and carrier. That's a major failure point of the 10's. Personnaly I think that it won't stand up to Pre running. They don't stand up to street driving. I blew one out at 60k in a very well maintained work van.
    Then there is the ring gear. problem. I don't know if you can reuse the 3.08 carrier. If it's the same as a 12 the carrier break is 3.73. Everything under 3.73 uses a series 3 carrier and 3.73 and above uses a series 4.
    Granade locker...if your going to fly this truck your going to experiance why it got that name. When it has a rapid wheel speed change like what would happen when you touch down...BOOM it will blow. Get something else like a Auburn or a Eaton Posi with Carbon fiber clutch pack if your going to go for a LS.
    Go 12 and truss. You could also go SF 6 lugh 14. Much stronger than the 10 and 12 but not the mass of a 14FF.
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, there are axles bigger than the 5 ton Rockwell. I'm not the Rockwell expert, so I couldnt tell you what is bigger. I have heard of a 20 ton axle before. /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    Why not give Mark Boyce a call and ask him? /forums/images/graemlins/thumb.gif
  17. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I'm actually running a 12 right now. In the course of my misadventures, I've picked up a couple of 10 bolts. They are basically my R&amp;D department, plus it will be nice to have something to bolt in when it's time for the 12 to get a rebuild.
    As for prerunning/racing, Pugsley was the man when it came to this knowledge, pretty lively discussion, but as many rearend threads that there are, it'd be a cold day in Hades to find it.
  18. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I don't think you Kansasans could give my hoes 24/7 to even let me afford placing the call to him. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  19. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    One thing I tried and worked for me was to spray some brake parts cleaner and then blow it off with air compressor, it fell off easy.
    You did remember to push the axle in a little to take it out did you? /forums/images/graemlins/thumb.gif
  20. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Well, if I needed an air compressor to blow, I'd called the ex.... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Reality, I don't want to brake clean them since the parts will be out for awhile......
    Yeah, I was pushing the axles in. Kind of surprised me since the other ten bolt, I had no problems with, the c-clips fell right out.
