lets talk about my steering problems.
Discussion in 'The Garage' started by colbystephens, Apr 1, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so i started my truck up for the first time today and went to take it out and it scared the piss outta me. now, i only drove this truck 3 times before it went under the knife, but it didn't do this then. during my build up i put a different axle under the front, but i don't think that's the problem. the steering is crazy loose. i couldn't keep the d@mn thing going straight (which was really scary with oncoming traffic on a narrow road in the rain w/ no wipers or seat belts :eek1:).
    *disclaimer - please forgive my overly-technical jargon*
    anyway, i notice that i can shake my steering shaft back and forth inside the dealy which goes thru the firewall where the steering shaft should go into the steering column (LOTS of movement). it can be moved a great deal. when i noticed this, i took a look at my buddy's truck and he has a part which i don't. the following picture is of his truck and what is circled is the piece i'm missing. is this what is causing me to be out of control? if that's the case, is it something i could easily pull off of a truck at the wrecking yard?
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I would look at the piece below it. The rag joint may be wasted. What year truck is that, so I know what model to go take a look at.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    When you put the new axle in have you set the toe and ensured the draglink is set properly? I the toe is off it can cause the truck to wander. The thing you have circled is a bearing that keeps the shaft centered in the column. I would have someone turn the wheel with the engine running and check the DL ends and TR ends to determine if any of them are warn causing the sloppyness. Also check the tightness of your box bolts as they can loosen over time.
    Ira
  4. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I would start with the things you changed first, tie rods, drag link ends.... Jack your truck up and with someone spinning the tire scribe a straight line all the way around the tire, do this to both sides and measure the differance (front to back side of tires)with the truck on the ground. What you want is 1/8'' toe in for 33-35'' and smaller tires and 1/4'' for larger tires.
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    hmmm. good info.
    i've got an 83, but have 78 running gear.
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    anyone got any thoughts about the effects of the fact that i can shake my steering shaft?
    hehe, i just said shake my shaft.
