Let's talk backspacing.. and 1-ton wheels..
Discussion in 'The Garage' started by XHitman396, Nov 16, 2005.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    so first off, i realize i hear it all the time, and i may have looked it up once, but what exactly is backspacing, and what is it used for (i.e. necessary to have 5" backspacing over 4.5" backspacing)? this will probably lead to another quesion (just so you know ;) ) and with a 14bff, is a 16 inch rim a must? or can you clear the drums with a 15"? thanks.. oh, and another random one, does all 1/2 ton break lines/pressures work for 1 ton breaks (10 -14 bolts)?? thanks again..
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Pretty picture:
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I run 15x10 with 4" of backspacing steelies on my 14bff with no grinding and a little bit on my 3/4ton front calapers. My 10b brake line matched up with my 14bff.
  4. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    about 4" backspacing is the max you'd want to go on a fullsize with large tires without rubbing steering or frame components. I've got 2.75" BS on 15x8's, but hate the look. They look fine to everybody I talk to, but I want them inboard of the fenders, so should have ground my caliper. 15" wheels will clear 14ff drums, but not front calipers, those can be ground down, but the backing plate/guard piece will need some severe clearancing or to be removed
    it's best to get your backspacing right in the center, ie, 4" on an 8" rim, the closer to the centerline the better it handles and less stress on the bearings.
