Lets talk Death Wobble
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Sep 18, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    My dw is getting worse. It was just whenever I touched the brakes, the tires would start
    wobbling left and right, but would always stop if i let the brakes go. Now once it starts wobbling,
    it keeps going after I let off the brakes. I know there are many factors that can contribute to dw,
    but I don't know where to start. THIS IS NOT BRAKE PULSTATION! The tires and sterring wheel
    actually ocicilate back and forth. Can someone help me.
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Try a search.............there have been probably 100's of responses/posts about it.
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    My parents purchased a 3/4 ton Sub in 80', From day 1 it had DW and the Dealership never found the problem. When you hit 35 mph the front end would SHAKE & the tires would start to JUMP off the pavement about 6-12"!!!! It was HARD to keep this rig on the ROAD!!!. It didn't do it all the time.....usaully when the Cops where behind me....But it did get even worse, when hitting the brake!!!!/forums/images/icons/crazy.gif
    This went on for years, the truck was reduced to a Plow truck.
    We replaced the tires and the problem wasn't as BAD.....
    What I would do is check everything for PLAY on you front- end:
    Ball Joints-uppers don't get much grease
    Tires-have you checked balancing
    Tie-rods-do they take grease
    Gearbox-is it sloppy
    Spindle Bearings-
    Anytime I get some vibs, those are the first things I check!!!
  5. Chris Demartini
    2,406
    Dumont NJ 07628
  6. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    i cured mine with a good satbilizer
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    The only cure is 4 wheel ram assist steering with 44" tires. /forums/images/icons/grin.gif
  8. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I have DW on my 60... seems to be a comination of things already mentioned... My end-all cure is to yank the stabilizer, install a hydro steering setup, and have the truck PROFESSIONALLY aligned. My tape measure in the driveway method is getting old! Figure that should resolve my problem. /forums/images/icons/smile.gif
    -Dan
