Let's talk snatch blocks.
Discussion in 'The Garage' started by 72THING, Aug 7, 2003.
  1. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Let\'s talk snatch blocks.
    Tell me what kind of snatch block you have and how it has held up. I'm debating which one to buy. I like the ones from Extreme Outback Products and Milemarker, but would really like your opinions and first hand experience before I order one. Oh, and my winch is a Warn HS9500. Thanks.
    Will
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Re: Let\'s talk snatch blocks.
    I have the milemarker one. Its quite smooth. havent needed to use it yet... but I really thought it was smaller! This thing is like 10 lbs.. its your standard snatch block style (top and bottom swing away from each other so you can insert line. ). Another nice feature is that it has a grease port , so you can grease it up. Looks like it should last the life of me.
  3. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    is that the same a COCK BLOCK just with chicks? /forums/images/graemlins/rotfl.gif
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
  5. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Yeah! It is normally the fat, ugly one! /forums/images/graemlins/tongue.gif
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I've got a couple, the most effective seems to be marriage. /forums/images/graemlins/tongue.gif
    back to the subject..
    My Warn HD version is really nice. I also have one of the sliding plate style (ramsey maybe?) that has come apart on me. The snap ring came off the shaft and the main pivot came out. Not while in use luckily so I just put it back together. I like the warn one better but it's really heavy.
  7. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    This post title really gets my attention for some reason... /forums/images/graemlins/grin.gif
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  9. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    Thanks for the recommendations. What's the weight rating of the HD Warn block? As I was typing the subject line, my mind instantly went to the gutter, too. /forums/images/graemlins/grin.gif
    Will
  10. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    That reminds of a song called "Big Fat Friend" by Steven Lynch. If you havent heard it, DL it as soon as possible.
  11. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I've got a cast iron "Skookum" # A 6, heavy with a swivel safety hook on the end. Picked up at a yard sale for $8.00. work's like a heavy block should, Good!
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't have one yet, but Rockstomper sells one that is rated for a 12K winch for $60. Warn wants $150. I am going to order one from Rockstomper when I get some cash, or buy one from a Wire Rope place here in Phoenix.
    Harley
  13. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Mine is a McKissick. It's rated at 12 tons (24,000 lbs), all swivels are greasable, and it uses 1" pins. The only draw back is it's heavy. You can get them from heavt equiptment places.
  14. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    Thanks, Jim. I had read some info on the McKissicks, but I couldn't swing the cash for it. Maybe one day. I ordered a treesaver from Rockstomper so I went ahead and ordered their snatch block. Its rated for 12,000 lb overhead lifting, over 40,000 lb breaking strength, and is a scissor style with a 1 1/16" pin, but isn't greaseable. It has an oillite bronze bushing in the pulley. Scott says he uses it on his rig, so it should hold up fine.
    Will
  15. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I looked at that one too. Sounds like a good buy. I just got lucky w/ mine.
  16. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    ok here goes me sounding lame...how does a snatch block work? isnt this winch-related?
  17. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    Yes they are used with winches, but are also used in construction, marine, logging, and other applications. It's simply a large pulley that can be used to double line your winch or to change the direction of pull. Here's what mine looks like from Rockstomper:
    Will
  18. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I have the one from Extreme Outback Products and it has held up really good so far. I like the fact that you can grease it w/out having to take it apart.
  19. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Here is the McKissick along w/ a standard shackle and a CUCV shackle for size ref:
