Lets Talk Welders...
Discussion in 'The Garage' started by RustBuket, Nov 10, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    So last fall I bought a little lincoln (like 80amps or something...up to 1/8th") to learn on. Its served its purpose. I've welded up a rear bumper and a few other little projects and I think I've got a general feel of it. I'm just sittin here thinking about this coming spring and wondering about what my next welder should be? Well it can't be 220v because I don't want to have to get my rents garage rewired, and I like it portable. I was cruisin ebay and came across this: link What do you guys think of these? Can they weld thin like body without too much warpage because my little welder doesn't have enough settings to go low enough for body...(can you say mega WARP!!!) And they definately go high in penetration and have flux core/gas capability. Give me your oppions on this welder and suggestions on other brands/models that are fairly inexpensive. /forums/images/graemlins/ears.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hobart 140.
    I have the 135 and it has done everything I've asked it to do, including weld 1" plate with multiple passes and flux core wire.
    I thought I wanted the 175/180 which is 220, but I'm glad I got the 135 because I got a great deal on it, and the portability fo 110v can't be beat.
    Someone borrowed it at a local 4x4 jamboree and welded their link mount back on the frame after they tore it off. They used a generator and did it right in the pits.
  3. RustBuket
    Feb 21, 2003
    1,618
    Cool, alright I'll keep the Hobart in mind. Anyone with oppions on the "Ready Welder" ?? I'm interested.
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    It looks like it is a spool gun to me /forums/images/graemlins/dunno.gif
    If it is you are still going to be limited by the output of your power supply /forums/images/graemlins/thinking.gif
    It may be good for alum. and stainless with an existing mild steel mig welder
    just a couple of quick thoughts /forums/images/graemlins/thumb.gif
  5. RustBuket
    Feb 21, 2003
    1,618
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I have the Hobart 135 w/ the gas bottle. It works GREAT... I have used it to weld lots of little stuff, built my entire cage w/ it, and built my winch mount out of 3/8" plate. The 110V welders cost about a 1/4 of a good 220V welder and will do most of what the average back yard mechanic needs.
    If you do decide to go w/ a welder that is 220V then there is only 1 name in my book...ESAB!
  7. RustBuket
    Feb 21, 2003
    1,618
    The gun says its good from 22 gauge to 3/4" steel if you read the specs.... Thats what I'm interested!! With that kind of versatility, it'd be AWESOME to have around.
  8. RustBuket
    Feb 21, 2003
    1,618
    Nobody knows about these things??? I'm also wondering about how long a batt might last.
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I think youd be better off getting a welder, instead of a spool gun. Dont get anyhitng with "Weld Pack" on it, its junk. A Lincoln SP 135, or 175. I must say, a 110 will work OK for the small stuff. I just used my buddies Lincoln and GEEZE. Id used it before, but it was a real PIECE OF CRAPOLA the otherday. Its 110, I cant wait to get me a real welder.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    I went with a Lincoln on the recomendation of a fabricator.... Plus they are made in Cleveland, OH which isn't far from me. The model I got is a Pro Mig 135 and have been very happy with it.
  11. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I have a clark weld 130 EN it works great with flux, then I bought a bottle and it works even better, I think it costs less then a hobart, but it only has 4 pre-set heat settings but infinate wire speed. It really works good. /forums/images/graemlins/thumb.gif
  12. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    I totally agree I'm running the same welder and it hasn't let me down! /forums/images/graemlins/weld.gif
  13. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    I have a "MILLERMATIC 251
    Welds material from 22 gauge to 1/2 in thick in a single pass. Perfect for metal fabrication, maintenance and repair, farms and ranches."
    Little more money but worth it
  14. RustBuket
    Feb 21, 2003
    1,618
    Alright, so that spool gun is just crappo then?
