Levelling Out
Discussion in 'OffRoad Design' started by Trailboss_jr, May 26, 2002.
  1. Trailboss_jr
    Trailboss_jr Registered Member
    Apr 13, 2002
    21
    Hamilton, Ontario, Canada
    What would you recommend if I went with a shackle flip, front and rear zero rates, and at least a 4" spring with HD shackle in front to level my 77 out??? Looks like with 1" extra from shackle and 1 difference front to rear, I would need another 2" in the rear, sound right????
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    The ORD heavy duty front shackles will only raise the front 1/4".
  3. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    With a 4" spring in front and the 4" flip in the rear, you'll probably want to just skip the front 0-rates and call it good. That will give you a theoretical 5" of lift in the rear with 4.25 in the front which has proven to work pretty well.
  4. Trailboss_jr
    Apr 13, 2002
    21
    Thanks Stephen, I was planning on going that way (5" in back and 4" in front) but your zero rates messed me all up and now I want to move the front forward an inch and the rear back an inch, which screws my plan (why do you come up with such things /forums/images/icons/crazy.gif). I kinda wanted to stay away from blocks to level out but looks like i'll have to use a 1" in the rear???
  5. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    If your only goal is to move the front axle forward, there are thinner ways to do it, we can make it work with 3/8 or 1/2" lift only. The parts are not as versatile as the regular 1" zero rates but they work. That sounds like the best option for you.
    Or you could drill a new hole in your spring perch, that works well within the space limits.
