Lever operated E-brake?s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1bigk10, Jan 20, 2002.
  1. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    Anyone ever put two levers in the cab connected to the e-brakes to use as turning brakes like in a sandrail??
    Of course you would have to have an open diff while using them?
    1982 K5 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  2. Glock Girl
    Glock Girl Registered Member
    Jan 15, 2002
    54
    NY
    I had "cutter brakes" in a old CJ I use to have. After putting it in front wheel drive You could lock up a wheel and piviot it right around really cuts down on turing radius. Tractors have been using the concept forever
    Shelby
    88 K5
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You don't have to have an open diff if you can run front wheel drive only (twin-stick), you just can't have a spool.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
