Levers are for sissys.........YOU NEED WRENCHES
Discussion in 'The Garage' started by 85mudblazin, Aug 1, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    So after having a hard time find the levers and springs for the caddy calipers, I got to thinking. I ended up using a 14mm wrench to connect to the caliper e-brake bolt. Then welded on a piece that lets the cable connect to the wrench. The cable is held in place by a piece of steel that is drilled to 9/16" and welded to the axle tube. Know the cool part is that when you push down the e-brake pedal and it sets the e-brake, doing this it tightens up the spring on the cable. When the pedal is released the cable un-springs releasing the e-brake. I only hooked up the driver side caliper but it alone works better then my old 10b drums ever did.
    Still gotta finifh welding and purdying up the e-brake stuff but Im happy it worked :D
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Guys at stoplights will think you forgot to remove a wrench off the caliper bleeder screw. :rotfl:
    The great thing is: if you can't find a 14MM or 9/16" wrench, you know where to get one if you do a little grinding. :wink1:
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Not to mention if I use a craftsman ill have a lifetime warranty on my e-brake :haha:
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I just saw your post at AK5 about it. I think it's awsome.. and look forward to seeing how it holds up. Looking at it, I would think it would hold just fine.
    Here is your alloted "ATTA-BOY" :bow:
    It looks like it should stay out of harms way well enough too.. which was my first concern. But looking at it .. I doubt it would hang up on much .. although anything and everything is possible.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Ill prolly cut off the back of the wrench to make it cleaner. Then I have to rework where the cable connects to the wrench, it was late and I didnt want to make alot of noise so I just used little pieces I had laying around the garage.
  6. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah I figured it was just a quicky fab.. and I knew you'd cut off the wrench.
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    As long as it works I guess
    h yeah, I damn near choked on my food when I saw that :haha: :haha: :haha: :haha:
  8. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    why cut it off... will be funny if someone ever tells you that you left a wrench hooked onto your truck :haha:
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Exactly. If anyone asks, tell them you started your crafstman "theme" truck after one too many episodes of American Chopper. :D
  10. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    :rotfl: :haha: :pimp: :saweet: :woot:
  11. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    Good idea, I just wish i could find the calipers though! I found a set about 250 miles from my house but the yard wont pull them :mad: , so im thinking of riding my motorcycle out there with my backpack on to pull them this weekend, would definately be cheap on gas that way! Ill hafta remember this one though, its brilliant :bow: .
  12. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    yeah, but didn't they use tools that hadn't been hardened yet when they did that tool bike, because they were worried that hardened tools would be too brittle and possibly break ? Hope that's not a problem
  13. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    This isnt exaclty a high stregth application though, they should be fine. think of how much umph is on em when your taking a nut/bolt off
