Lifespan of a Red Optima? Update - found the problem, PermaCool relay
Discussion in 'The Garage' started by jms, Apr 27, 2003.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Found my elec problem - turns out there WAS a draw on the battery. Reason I'm posting this here: it's the PermaCool relay to run the two electric fans (PermaCool, 14" fans, relay is the one that came with the temp sensor). Started the truck this afternoon, and 'crack' the relay explodes and starts smoking and burning off the insulation. I had installed this last spring when I went with electric fans, by the book, no ghetto rigging, fuses everywhere, and it was working pretty much as advertised, apparently until some time recently. Reason I think the relay was the culprit is that as soon as I disconnected the relay, the battery started to take charge from the alternator. Now, I hadn't touched any wire or connected something new/different in the last six months, so this thing pretty much went without warning (or maybe the discharged battery WAS the warning!) - I thought some of you might want to know.
    Found my main battery dead yesterday. Truck had sat for a month on jackstands for the shackle flip, front lift, and rear spring pack rebuild/greasable bolts all around. Finally finish, and turn the key - nothing, not even the lights in the dash. Started the truck from the auxiliary battery (Wrangler NW system) just fine. Both batteries are red optimas, main is five years old, aux is four. My el cheapo voltmeter sez aux at 11 volts, main at 4 volts. I know the voltmeter always reads low, so I think the aux is fine, but the main is probably pretty much dead. Never had any indications of problems with it, truck's garaged all year, and didn't have any drain on the bat that I was aware of, didn't leave the lights on or had the radio on while working on the truck. So, a few questions: is my main bat just at the end of its life span, and any recommendations for a decent voltmeter? And, what's the opinion on batteries these days, are optimas still the ones to get, or is there better stuff out there? thanks, michael
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Re: Lifespan of a Red Optima?
    7 years or somthen like that You should be able to charge it and if you cant take it back to where u bought it
  3. jms
    Jan 24, 2001
    1,683
    Thanks, taking back won't work, got them while I was living in San Diego /forums/images/graemlins/smirk.gif
  4. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    try recharging it with a slow trickle charger. they like that
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    if it turns out to be completely dead and none of the stores in your area will honor the warrany b/c you didn't buy it from them, then call the company, most company's will try to help you out. i had a set of monroe shocks on my K5 that blew a seal. i ended up calling monroe and they sent me a set completely free of charge. they sent both for the rear even though only one of them went bad.
  6. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Mine did the same thing, 2 day trickle charge while I finished my work was all it took...still going strong.
    Chris
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Try a long slow charge(1-2amps) overnight let rest during the day(no charge), repeat till it will start the vehicle.
  8. greybeard
    greybeard Registered Member
    Sep 29, 2000
    43
    Dallas, Texas
    About a year and a half ago, I starting having trouble with one of my red tops. It wouldn't hold a change. At the time, the battery was over 5 years old. The place I bought it from had gone out of business. I went to Interstate's website www.interstatebatteries.com and looked up the local distributor . I took the dead battery there and, after testing it, they gave me a new one. I didn't even have to show them the receipt! I'll bet there is a distributor in Omaha. It might be something else to try.
  9. jms
    Jan 24, 2001
    1,683
    Thanks, I'll try the website, that's a good idea. I've never done the trickle charge with gel batteries, but my previous experience with regular plate/acid bats hasn't been too great - the charge usually bought a me few months time but then it was over really quick. Right now that would be fine, just driving about town, but I'm not sure I trust a battery like that on a long desert trip...
    Anybody have an idea about where to get a good brans of a voltmeter?
    The NAPA guy showed me one - for the price of a new Optima, not quite what I had in mind.
  10. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    mine went bad after only 1.5 yrs, took it to 4wp(thats where i bought it) and they replaced it no questions asked, they had a copy of the reciept on my name in the computer so i dint need to bring one in.
  11. jms
    Jan 24, 2001
    1,683
    Update at top, pertains to electric fans, so this may be of interest.
  12. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    a good brand i have is a "fluke" voltmeter; actually it will test a lot more than volts, i also have an el cheapo that i throw in the box to go wheeling with /forums/images/graemlins/rotfl.gif
    here are a few on ebay: http://search.ebay.com/search/search.dll?GetResult&query=fluke&from=R10&ht=1&currdisp=2&itemtimedisp=1&st=2&category1=4676&Top10=&SortProperty=MetaEndSort&catref=C1 /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
