lifetime of a 6.2
Discussion in '1982-Present GM Diesel' started by 89Jimmy, Jul 5, 2003.
  1. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    Hello,
    I have run Jimmys and k5's since 1989, but always had 350's in 'em. I'm looking at a '86 with a 6.2 and a banks sidewinder turbo kit with a 700r4 tranny. According to the sales schpeil the engine was installed about 60,000 miles ago and the turbo kit about the same time. I'm curious about the life expectancy of the mill. Is 60k a lot of miles for a turbo equipped rig? Are there any major turbo maintainance issues that I should be looking for? I really like the truck and have been wanting a diesal for some time, but I don't want to make a costly mistake because of my ignorance of diesals. Any input from you guys would be greatly appreciated. Thanks. Put your hand on the injector pump and shout, "I BELIEVE"!!!
    John
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    60,000 miles on a diesel???? LMAO that thing is still new,LOL
  3. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    With decent care,,,,somewhere around 200-300K miles or so. I replaced my NA 6.2 at 240K because it needed a injector pump. The motor itself was fine, it's just that the new pump was going to be around 300 bucks or so {if I remember right} and I found a used 6.2 with 60-70K miles on it for 500 bucks. Couldn't pas it up.
  4. edeslaur1
    edeslaur1 1/2 ton status
    Jun 23, 2003
    193
    Oregon City, OR, 97045
    The biggest killers are as follows:
    Cracked vibration damper = broken crank
    early glow plugs overheated & blow up
    early glow plugs swell and break off in cylinder when removed
    Timing chains stretch & may need to be replaced around 100K
    injector pumps wearing (and they're not cheap)
    Mine has 96K miles and doesn't use oil. I'm pretty happy with it overall.
    Oh, w/ the Banks, it should be putting out around 207hp and 396 ft/lbs. That's about 66 ft/lbs more than a TBI 350 at its peak year. Even the new ones are only 325 and muuuuch higher on the powerband. Check http://www.bankspower.com for a graph.
    Finally, think of the mpgs...
    My 6.2 is getting 10mpg in an 11,500# motorhome w/ a TH400, no lockup converter, and the injector pump is leaking at the throttle shaft (yes, a new pump is on order). I should be back to 16s in no time.
    The things you DO wnat to consider is that the 86 TH700 was pretty crappy. They didn't get good until 91ish. And the rear axle is 28 spline.
    With that much torque, those are the two things I'd be worried about, not the motor.
  5. 89Jimmy
    192
    Thanks for the info. I've got a 30 spline 10 bolt rearend out of my '89, if needed, and I've also got a 700r4 that was rebuilt by our local tranny place to what they call their "plow package". I think it uses some later year parts. I think that the diesel trannys have some different specs. I'll have to check that out. I have spent some quality time on Bank's website. (Tough to stop drooling). What do you mean by "early" glow plugs? Can the balancer be checked visually for cracks, or is there some other procedure? Thanks.
    John
  6. edeslaur1
    Jun 23, 2003
    193
    Yeah, just look for cracks or if the rubber is squishing out of it. If it's oil-soaked, definitely fix the leak and get a new damper.
    The diesels use a different converter & that's all AFAIK (definitely check).
    http://www.bowtieoverdrives.com has a great article on setting up your TV cable so you don't munch your tranny.
    I'm jealous about the Banks, have fun!
    Oh, consider a membership to http://www.thedieselpages.com. I've gotten a lot of good info from those guys.
  7. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Looks like Banks gets the hp estimate right but sells things short in the torque department.
    With a rebuilt injection pump amd injectors, 3* timing advance, k&n filter, Stanadyne performance formula, J-code intake, banks stinger, and a sidewinder turbo, the project blazer made 172 hp and 451lb/ft of torque on the chassis dyno.
    Those were rear wheel numbers.../forums/images/graemlins/thumb.gif
    Rene
  8. edeslaur1
    Jun 23, 2003
    193
    Where'd you get the quote from? I want to find out more about the pump he used.
    That's incredible for RWHP #s. Bump 'em by 20-30% for drivetrain losses (20% on my M3, 30% on my XJ).
    TIA!
  9. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
