lift advice
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hank75, Jun 6, 2003.
  1. Hank75
    Hank75 Registered Member
    Nov 30, 2000
    31
    i have a 75 blazer currently with a 4 inch rancho lift blocks in rear, i just bought 36x12.5 tsl radials. My question is what are a couple of options to make these tires fit? ord flip, straight suspension lift or will they fit with some trimming. cant wait to get them on
    /forums/images/graemlins/cool.gifthanks
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Trimming fenders or a body lift...
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    you mentioned blocks in the rear (eck)...what do you have in the front? You can do a homemade shackle flip in the rear for 4" lift and ditch the blocks...add in a 1" zero rate for 5" and trim the fenders a bit. I got a set of 4" superlifts from a friend for my front and a 3/4" zero rate, then did a homemade shackle flip in the rear using the front spring mounts from a 2wd truck and a 1" zero rate. I can fit in 35s without rubbing but it is close. I will be trimming the fenders when I put em back on (long story).
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    best option: shackle flip in the rear (to get rid of those blocks)... and trim the fenders to fit the new meats.
    j
