Lift and axle swap questions. Need info soon!!!
Discussion in 'The Garage' started by unick, Feb 8, 2004.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Ok im going to a 6" lift and 1ton gear in the near future Im hoping to do it before the first weakend of march. Ive got a list of these things I will need so far.
    D60
    14bff
    bilstien 5100 14" travel shocks
    f250 shock towers
    conversion u joints
    spare tire
    5 rims
    brake lines
    lift springs
    new suspension bushings
    Extended drive shafts
    Am I missing anything? Also where can I get conversion ujoints and how much do they run?
    LMK
    Nick
  2. 78GMC1/2TON4x4
    78GMC1/2TON4x4 1/2 ton status
    Mar 10, 2003
    167
    Mount.Angel, OR
    longer U bolts
  3. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    If you are lengthening driveshafts get the right yoke put on the shafts and forget about the conversion joints...
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    u can get conv. joints at any parts store. local they are $25. if u are going to spend much money having your d-shafts modified it would be a good time to have the right yoke put on it, so u could run a regular joint. /forums/images/graemlins/thumb.gif
    good luck on your swap u will love it.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    What are you planning on doing as far as the lift in the rear ?? I'm a big fan of the ORD Shackle Flip. Great product in my honest opinion. /forums/images/graemlins/deal.gif
  6. unick
    Aug 16, 2003
    4,286
    Ive got an AK57 6" for the rear
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]Nice !!!! /forums/images/graemlins/waytogo.gif
  8. unick
    Aug 16, 2003
    4,286
    yea thats y i want to have all this done by the first weekend im March so I can go to TDS!!
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Brake fluid, spring plates & ubolts for front and rear. /forums/images/graemlins/thumb.gif
  10. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Not really longer u-bolts but wider ones for the 14 bolt. Compleat set at Napa is like $15.00
    You will need some way to remove rivits on the stock front shock tower. Either drill them out or grind the heads out and knock them out with a center punch. Either way I would make sure I got good bits and or a good grinding wheel. The F-250 towers will need a couple inch's trimed off of them so You will need a torch, cut off wheel or chop saw. Also You will need some grade 8 hardware to mount them I belive it would be 3/8's
    Oh and a BFH and lots of other tools. /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
