lift and drive shaft ???
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 71blaz, Mar 27, 2003.
  1. 71blaz
    71blaz Registered Member
    Aug 1, 2002
    86
    southwest colorado
    I just finished installing a tuff country soft ride 2" full lift. This included 2" front springs 4" rear springs, full greasable bushings and front shackels from ord.I took measurements before and after and I netted 3.5" of lift in the front and 4" in the back ,so it still saged in the rear /forums/images/graemlins/frown.gif so I got some zero rated and that fixed the problem. The stance is now great.So here is the problem the rear drive shaft in now 1" short at full extension, So really it's about 4.5" to short.The rear springs are not symetrical ~1" different from eye to pin.I put the 1" to the rear to center the tire and intalled the zero rates with no offset.So anyone else have this and suggestions on the drive line?have a new one made, get the existing one made longer ????? and is this common ?
  2. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    hmmm, I can't hlep you, but out of curiosity.. what are zero rates?
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
  4. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    if you check out www.offroaddesign.com (most people simply call them ORD) you can read up on Zero rates. Much better than blocks IMO. Essentially they are a zero-rate spring that bolts to your leaf pack and gives an easy/quick 1" of lift. Since they bolt to the spring pack they can be safely used both in front and rear.
    -Ryan /forums/images/graemlins/k5.gif
  5. '72brett
    Dec 3, 2002
    166
    northwest Iowa
    sweet. thank you for teaching me something new. Im good with engines, but the suspension end of things I am not educated on.
