Lift and steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Loose Nut, Nov 15, 2005.
  1. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    Im about to install some lift (6inche's) and ive read and cant remember where to save my life but isnt there a steering setup i need to use to keep from having problems after the lift.
    i dunno if what i said makes sense, blame it on lack of sleep i quess. :eek:
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Cross over steering would be ideal, but it's a bit expensive. If you aren't into crazy flex, just a raised steering arm (comes with most kits) on the axle will do fine. A frame brace would be a good idea too.
    :D
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    The main thing you should be concerned with is your steering angles. Your draglink should be as parralel as possible. You will need to get a dropped draglink or a raised steering arm to correct your steering. Crossover steering would be good too, but expensive, and not what your lookng for.
    Few other things to consider is longer brakelines and driveshaft length.
    Jesse
  4. divorced
    Jul 20, 2004
    5,115
    Parallel to what? The ground?
    The drag link need to be parallel to the arch of the spring, as shown in this pic
  5. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yeah yeah, now go radius the corners on those shackles. :grin:
    if you actually take your rig offroad, you'll want x-over steering eventually. Only real question is, do it now or wait till the 1-ton axle swap...
    j
  6. 81jimmyslt
    Jun 5, 2003
    1,643
    ahhh no not the springs, on the push pull style (non crossover) you don't want an arch like that.
    For crossover parralel to the tie rod, ground, axle tube what ever.
  7. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    Are there any kits i can purchase that would allow me to have a decent set up? Im from the east coast and ill be wheeling on alot of rocks.
