lift and tire question need help
Discussion in 'OffRoad Design' started by offroadbilly, Apr 11, 2006.
  1. offroadbilly
    offroadbilly Newbie
    Apr 11, 2006
    patterson, ca
    i just bought a 1985 full size jimmy. according to the door it had 32" tires from the factory with 16" rims. i got it with 33's on it now. my question is what do i have to do to fit 35's? from what ive been reading (correct me if im wrong) must blazer/jimmy's had about 30" tires from the factory. my concern is if this jimmy can fit bigger tires from the factory then it must come from the factory taller then most, basicly what im saying is, i dont want to buy a 4" lift kit if its only gona make my jimmy 2" taller since its already 2" taller than the regular k5. the 33's dont rub at all and there is no sign of any lift whatsoever
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    then you will most likely need to lift it or start:hack::grind:
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Some 33's are not 33" tall. Some trucks will run them without problem and no lift. I have never heard of one coming from the factory with a lift. Dealers put them, on sometimes. A 4" lift with some trimming will let you fit 35's.
    Ask this in the Garage and you will get more responses.
  4. redbeast77
    redbeast77 Registered Member
    Mar 3, 2006
    5
    Florida
    Yea, The Procomps for example - from what I saw or the order specs their "33's" are just about the same size as their "31's" - weird! I'm not sure why it's advertised as a '33' then. :confused:
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
