lift and tires combination
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88bblazen, Nov 17, 2004.
  1. 88bblazen
    88bblazen Registered Member
    Mar 23, 2004
    32
    SouthTexas
    What is the biggest lift and tires combination i can do without modifying the vehicle. I have an 88 fullsize blazer auto 4x4 v8 i have 33's on it now with now lift. /forums/images/graemlins/k5.gif /forums/images/graemlins/hack.gif <font color="blue"> </font>
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Not sure I get the question. A lift is modifying the vehicle. It also depends on what type of wheeling you do. I say to avoid most of the rubbing go for 35's on a 6" lift. Just watch if you flex it. I am a fan of a 4" lift with 40's but that is just me.
  3. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    I am gathering that you want to know how big of a tire you can run on a stock heigth K5. Right? /forums/images/graemlins/dunno.gif 33x12.50 is about it.
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    4" and 37"s with minor steering correction brake lines and trimming
    Past that its drivelines, crossover, etc
  5. 88bblazen
    Mar 23, 2004
    32
    SouthTexas
    Can i run a 6 inch lift with 35's without driveshaft problems or any driveline probs. Thanx again for the help. /forums/images/graemlins/k5.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif
  6. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    with 6" lift you will need to get longer driveshaft's
  7. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    ...and brakelines...
  8. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    His is an 88 and is identical to my 85( I have a 241 though) and my stock drivelines worked fine with my 6" kit. The only reason why I finally had shafts built was because the rest of my drivetrain was in good shape and that rear shaft with the 1310's was the weak link. Plus I wanted a cool 4" shaft. /forums/images/graemlins/histerical.gif I'm running the stock shaft up front but it's lengthened and rebuilt.
