Lift block pins
Discussion in 'The Garage' started by 74Chev, Aug 27, 2004.
  1. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    Does anybody know where to source the small pins that go into the bottom of the lift block and into the axle pad. The ($*&(# auto parts store guys around here say they have never hear of such a thing. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif I am trying to get the 1 ton stuff out of my 74 pickup and under the Jimmy and this is holding me up.
  2. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    call me crazy, but i thought those were integrated into the block...if not, check out thier lift blocks(the part store downt the street from me seems em for like $20) /forums/images/graemlins/dunno.gif
  3. 74Chev
    Sep 19, 2002
    102
    Oregon
    I think that some are, but I know that when I put these in 10+ years ago the pins were separate and now one stuck down in my 14 bolt. I need to get a new pin so I can get the 12 bolt under the pickup to sell it.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I bet if you heat it with a torch it will come out. Even a propane torch is your friend here. /forums/images/graemlins/thumb.gif
  5. gonecheenin
    gonecheenin 1/2 ton status
    Aug 8, 2004
    111
    Vandergrift, PA
    I've used .50" long, 3/8 coarse thread allen head bolts for that exact purpose
  6. 74Chev
    Sep 19, 2002
    102
    Oregon
    I would do that but my darn torch is about 100 miles away from me right now. I thought that someone might know of a parts store that might carry these stupid things. I can't believe that this is holding me up. I really hate to do a ghetto job on the truck I am selling to a friend.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Why not just get leaf spring center pins? You can get them in varing lengths.
  8. 74Chev
    Sep 19, 2002
    102
    Oregon
    That will not work becasue they will not fit into the lift block. Those leaf spring pins are threaded rod with a larger head/pin.
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Go to your local hardware store and buy drill rod of the proper size or a little larger and machine to fit. /forums/images/graemlins/thumb.gif
  10. diesel4me
    Jul 24, 2003
    17,540
    935
    Massachussetts
    Try a machine shop--I bought a chest of drawers from one that was cleaning out the shop at a sort of yard sale they had when relocating,and they were choch full of nuts,bolts,cotter pins,pipe fittings,air hose and hrdraulic hose fittings,ball and thrust bearings,and a whole drawer full of solid dowel pins,probably just what you need--and I have never needed yet so far--too bad your on the other side of the U.S.A.-.
    Maybe you could rob the dowel pins out of a junk block ,there are two on every chevy motor in the bellhousing--not sure,but they might be 7/16" though,maybe too big for what you want them for.But I bet a machine shop has lots of those pins,they use them in jigs to set up milling machines and other machine work. /forums/images/graemlins/crazy.gif
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I think they are 9/16", but I'm not sure. I made some once out of some bolts. I used grade 8 ones and cut out the section that is not threaded.
    You might be able to get the old one out, though.
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I lost the center pins on my blocks, and used a small 1/4" socket that fit the size of the hole. Use a deep socket and cut it to length if need be. I ran that for years. Still on the truck actually...I need to do a shackle flip or somethin to ditch the things... /forums/images/graemlins/yikes.gif
