Lift block removal
Discussion in 'The Garage' started by jdx1177, Apr 21, 2007.
  1. jdx1177
    jdx1177 Registered Member
    Apr 21, 2007
    6
    canada
    I have a 4 inch block lift on my k10 with rancho shocks for a 4 inch lift and i want to remove the lift blocks because they suck. can I keep these shocks or do I have to get new shorter ones.
    thanks
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Do you want to keep it with 4" of lift or do you want to lower it back down to stock height??????
  3. jdx1177
    Apr 21, 2007
    6
    canada
    stock height
  4. Corey 78K5
    13,055
    Humboldt County, CA
    Then yes you will need new shocks.....
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If you lower the rear, what about the front?
  6. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
  7. jdx1177
    Apr 21, 2007
    6
    canada
    wow thanks for all the great help. i definately like the ORD rear shackle flip kit but what do i do about the front
  8. cbbr
    Jul 17, 2004
    14,681
    If you have 4" blocks in the rear, I would have guessed that the front had lift springs. Please tell me that there are not blocks on the front??
  9. jdx1177
    Apr 21, 2007
    6
    canada
    yes unfortunately lift blocks on the front. This is a truck that has been parked a while that i acquired fairly cheap. It came with them on there already.
    So i need to get a set of lift springs for the front then ya? then get a flip kit for the rear new u bolts for the rear and might as well go for new shackles and hardware as well. All this to keep my lift and shocks. the bonus would be that the lift would actually flex instead of being rock hard.
    or i could remove lift blocks front and rear get new u bolts and shorter shocks?
    but It has 33 inch tires on it so i would have to trim the wheel wells but they are rusty as hell anyways(I'm in the northeast) so thats not a big deal.
    any opinions on this. Am I overlooking any potential extra cost in either of these options
    thanks again for the good info
  10. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    What province/town are you living in man??
    If you are close I could help you out. I'm always looking for someone to wheel with.
  11. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Looks like you have it covered. Don't drive that with blocks on the front. New U-bolts all the way around.
  12. lectric80
    lectric80 3/4 ton status
    Apr 4, 2007
    9,508
    Grantsville, Ut
    I can tell you that I am running an 80 K5 with 33's on stock suspension. No fender rub whatsoever. That is with no trimming to the fenders. Clears under most circumstances, but I haven't tried anything really extreme.
  13. jdx1177
    Apr 21, 2007
    6
    canada
    AZ79 just so I am clear. new shorter shocks as well?
  14. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Removing the front blocks is a must. New U-bolts for anything you replace are also needed.
    Here are the options you have:
    1. Remove both blocks, replace the shocks and run stock height. The 33's will probably require fender trimming. I trimmed mine with 33's and a 4 inch lift because of tire rub.
    2. Remove the front blocks and replace the front springs with a 4in - retain current ride height.
    3. Remove both blocks, replace the front springs with a 4in lift, drop in a shackle flip - retain current ride height.
    Depending on the shocks' condition, they may need to be replaced no matter what.
    One thing that gets overlooked is zero rates with the shackle flip. Your rear axle is moved forward slightly because of the rotation on the front hanger with the rear hanger lowered. The zero rates allow for the axle to be moved back to the center of the wheel well.
    Some reading for you on zero rates:
    http://coloradok5.com/forums/showthread.php?t=196636
    http://coloradok5.com/forums/showthread.php?t=204995
    http://coloradok5.com/forums/showthread.php?t=198604
    The link to ORD has the zero rates http://www.offroaddesign.com/catalog/Zero%20Rates.htm
    Good Luck.
  15. jdx1177
    Apr 21, 2007
    6
    canada
    Ok cool.
    Thanks for laying it out so clearly.
    I'm gonna go with stock height. new u bolts. definately
    new shorter shocks. maybe
    but im also tempted to do the rancho shock mount relocation with new longer shocks.
    http://www.coloradok5.com/ranchoreview.shtml
    any thoughts
  16. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    I would only do that mod if it was needed b/c of suspension travel. That seems like a LOT of work to do just to do it.
    What's your build goal with this truck? What type of truck are you looking at having when it's "done" if that day were to ever arrive?
