Lift blocks for the front axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deek, May 29, 2003.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    Is it possible to use lifting blocks on the front axle, even if it is just a 1" zero rate block?
    /forums/images/graemlins/k5.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> A zero rate, or any 1" block that bolts to the spring pack with the center pin, should be fine. Anything taller is asking for trouble. </font>
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    ya what shaggy said /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    agreed. whatever you do, dont ever ever ever put any kind of block up front that isnt part of the spring pack. baaaaaaaad idea. /forums/images/graemlins/smile.gif
    j
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    A zero rate is nothing more than a glorified block in my opinion. Even if it does bolt to the spring pack it still increases the torque arm length like a block without spreading it over the leaves. So even though its a lot less likely to fall out and cause a catastrophic accident it's still nothing more than a glorified lift block.
    In Michigan, if a cop knows the law and sees you with a zero rate on the front axle you'll get a ticket. However, most of them won't notice a raised spring perch which does the same thing.
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    thats all ya had to say. /forums/images/graemlins/grin.gif
    j
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't say a lot less likely. I'd just say less likely. A block is a block, PERIOD.
  8. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    if its part of the pack, a zero rate is really no different than a spring pack with more leaves in it. Is a 4" lift spring with a ORD zero rate block in it more/less likely to cause a problem than a 12" lift spring?
    j
  9. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    If you think about it, it does stress things more than a leaf. A leaf will attempt to spread its weight over the other leaves more towards the eyes. A block puts it all right there at the center of the leaf and adds a longer torque arm length to boot.
    EDIT:
    PS: An overload leaf does the same thing as a zero rate (doesn't contact the rest of the spring back anywhere but in the middle).
  10. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Of all the people on this site that run 0 rates in the front and thrash their trucks, when is the last time you heard of one causing a problem? /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/deal.gif </font>
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    go a step further
    of the thousands or more commercial vehicles running front blocks how often do you hear of them having problems?
    breaking a centre pin is common
    blocks are a bad shortcut IMO
  12. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    the key is maintaining the vehicle. If you had blocks up front, as long as the ubolts were properly torqued, you would be "less" likely to have them pop out. Probably would want to have a scheduled ubolt change as well.
    If your like most vehicle owners, you do not fix things until its broken. Thats why the laws exist. There is alot more stress on the front end with weight shifting factors.
    I had zero rates on my front end before putting lift in. The condition of the old springs and pin was HORRIBLE. I have since changed my ways, but was most likely asking for trouble running that setup.
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    blocks are not as sinful as many make them out to be,
    but they still arent the best way
    and I would never recommend them
    better to do it right
    there is enough info on this site to figure out a longer front spring that will move the axle forward and ride better then most aftermarket chev 'off the shelf'
  14. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Well, a trac bar will solve the front lift block problem /forums/images/graemlins/thumb.gif
  15. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    EDIT:
    Yes and No.
    At ride height it only contacts the middle of the spring (i.e. not adding to spring rate.....it's intended purpose), but as the spring compresses (under load) it spreads it's load out toward the eyes (although not as much as a typical contoured leaf).
    To clarify, I would not "recommend" doing either (although in moderation it is NOT a sin). A zero rate and/or helper/overload spring is better than just a stacked block, but the correct solution is to buy a spring pack with the correct lift and spring rate for your application.
    Regardless of which way you go, checking u-bolt torque and center pin at regular intervals is always advised.
