Lift blocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kristoffer, May 23, 2001.
  1. kristoffer
    kristoffer Registered Member
    May 21, 2001
    32
    Norway
    i have "2 lift blocks in the rear of my truck, and the one have cracked, is that normal for lift blocks???!
    but i need new ones, where can i get the "2 maybe 3" lift blocks? any web pages on the internett?
    sorry for mye bad english!
    Kristoffer S
    Norway
    Kristoffer
    1977 blazer k5 cheyene
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    That is not normal.....What kind of driving do you do? If you have the $$$ go for some rear 3" springs!
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  3. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I hate rear blocks. Have you herd about ORD's 2.5" rear shackle flip? -Tommy
  4. 1big78k5
    1big78k5 Registered Member
    Apr 1, 2001
    92
    moosup, ct. usa
    When going with a 2" or 3" block you should have no problems at all. They will be really cheap to replace to, about $30.00 Go with the shackle flip if you have the money but a running a lift block that small will give you no trouble.
    '78 K5 SB400, T350, NP203, 35" Swampers
  5. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    What were your blocks made out of? If they were aluminum that is your problem. Every aluminum block I have ever seen has broken or cracked. Get yourself a set of steal blocks and you should have no problems. Never saw one of those busted.... if you did break a steal block I would love to see it!![​IMG]
    Mike
    You call that dirty!?
  6. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    Replace the blocks with springs. It is well worth it, you don't have to worry about cracking them while on the trail and popping out. That could be messy.
  7. kristoffer
    May 21, 2001
    32
    Norway
    They was made of aliminium.
    I jumped with my truck yesterday, maybe that did it! :)
    i think i have 2.5" - 3" Springs but the rear was saging and i puted the blocks on to get it up.
    Where can i gey the blocks in Steel!? any plase on the internet??..
    Sorry for my bad eglish! hope you understand me!
    Kristoffer
    Norway
    Kristoffer
  8. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I may have a pair of 3" blocks some where. It's been so long I can not remember what I did with them. IF I find them you can have them(that's a big IF though). You just have to pay me for shipping. I live above a UPS drop off so it will be no trouble at all. The only trouble will be finding them. I'll let you know one way or the other by Tuesday.
    That's because I'm the devil.
  9. kristoffer
    May 21, 2001
    32
    Norway
    Thanks but i have talked to a friend who works on a "mecanical shop" and he is going to make me a set of new ones.
    i need also to get my truck 1" up in the front, what is the best thing to do then?
    Kristoffer
  10. Oddball
    Oddball Registered Member
    Dec 28, 2000
    46
    Norway
    Call BG-nor in norway+ 47 22079660
    www.bgnor.no
    They got lift blocks in cast iron.
    1977 K5 " Earthquake "
  11. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    You can get ORD's 1" zero-rates... they are kinda like a block but attach to the spring pack. Blocks are a no-no up fronts... you could also go add-a-laefs but that will harsh'n the ride. ORD's are the way to go IMO.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
  12. kristoffer
    May 21, 2001
    32
    Norway
    Thank you all for the HELP!!!!!
    Oddball are you from Norway??
    Kristoffer
  13. Oddball
    Dec 28, 2000
    46
    Norway
    Yes..
    Stavanger
  14. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i had a set of 2" cast ones break on me as well. i had a set made from steel and never had another problem. the aluminum ones should be a crime.
  15. mpascino
    Jan 1, 2001
    557
    Connecticut
    You could use extened shackles in the front to get the extra inch and then use a 3 degree shim to striaghten the pinion out. It's pretty easy and I have have no problems with it plus it will make the truck flex like a pretzel
