Lift & crossover pipe question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Topher, May 12, 2000.
  1. Topher
    Topher Registered Member
    May 12, 2000
    81
    North Texas (DFW)
    Hello guys,
    I'm planning on installing a 4" lift on my daily driver '85; it currently has add-a-leaves all around and 33x12.50r15's. I have a single exhaust with a crossover pipe that crosses below the front driveshaft just in front of the NP208 T'case. I can only eyeball it at this point, but I imagine that lifting the vehicle a few more inches would cause the driveshaft to come dangerously close to, if not actually contact the crossover pipe (it more than likely would under any compression of a 4" suspension I think). Yet I'm not 0 positive.
    Anyway, I have no qualms about modifying that section of the exhaust if it comes to that. So I'm curious as to what y'all with similar setups have done to your crossover pipe. How have you re-routed your exhaust to accomodate a lift? I would like to stay away from a "complete" re-design of my entire exhaust if possible; I'm sure a competent shop could fix me up with a custom setup but I don't think I could afford that at this point.
    (My '78 with 6" susp, 3" body & 40" mudders has headers & dual exhaust so the crossover pipe wasn't a concern)
    Thanks a ton for any tips/info anyone can provide.
    Great, great site! Been lurking for awhile but finally registered today and this is my first post...yippie!
    Chris S.
    DFW, TX
    85 Jimmy & 78 K5
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Well, if your '85 is set-up the same as my '87, the crossover (Y-pipe) is ahead of the cat. If you have emissions checks in DFW, modifying the crossover is technically illegal, since it is considered emissions equipment (d@mn tree-huggers!). This is an expensive solution, but I know Thorley's Tri-Y headers come with a new crossover and a CARB EO so they're 50-state legal. You can get them with a crossover made specially for lifted Blazers, too. I believe the site is thorleyheaders.com.
    Of course, if emissions checks aren't an issue, do what you want and have fun!
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
  3. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    My 88 K5, 350 TBI, 700r4, np208 & rancho 4" springs with stock front shaft and exhaust clears just fine. Articualtion and all that stuff is no problem.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
