Lift for 35x14x15 SS's
Discussion in 'The Garage' started by clubba68, Sep 29, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Lift for 35x14x15 SS\'s
    I am going to put my 35x14x15 SuperSwampers on the first gen. I have 4" Rancho (stiff as hell) on there right now, but I am switching over to the TC EZ Rides. Just wondering in you guys' opinion what lift I should go with 4" or 6".
    Am I going to have to do any drivshaft mods with the 6" TC lift? Want to do pretty minimal fender trimming, but it is also my Daily Driver, and it needs to keep some of its driving integrity. The thing is already enough to handle with 4" and 33's so I would like to keep it as low as possible, but is 4" just too low for those tires?
    Thanks,
    Andrew /forums/images/graemlins/usaflag.gif
    BTW - I am switching lifts to the TC EZ Rides no matter what. Also I think I am going springs all around and no shackle flip in the rear. I would like to have same spring rate front and rear and matching springs instead of shackle flip. Let me know what you think. Any pictures of your rigs would be great too. /forums/images/graemlins/1zhelp.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Lift for 35x14x15 SS\'s
    Even if you use springs all around, you wont have the same spring rate front and rear. That's not going to happen...that's not how a truck works.
    If you use a shackle flip, the rear will be soft, but still not softer than the front.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    if spring rates were the same front and rear, unless there was a good arch difference the front would sag do to the weight.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    well i had 33's and 4" BDS, hadta add a 2" body to clear my 35x14.5 SSR's cause i didnt want to cut my fenders, I could get away just barely cutting the edges but im chicken, and my truck is pretty straight with no rust.
  5. clubba68
    Dec 6, 2002
    1,511
    I actually did know that there would be a spring rate difference front to rear. Don't know why I wrote that. I was just interested in keeping with the spring lift all around. Do you guys think a shackle flip would be better than rear springs (the cost doesn't really matter), and do you think 4" or 6" suspension, or 4" with w/ shackle flip or 6" w/ shackle flip and 0 rate add-a-leafs?
    Thanks,
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I have a TC EZ ride 4"....My 35x12.50's fit fine, although I don't get to crazy with it yet....The clearances are pretty close, I think you might have issues w/the wider tires. Each rig is a bit different....
    I like the way mine rides, but I will be looking for some adjustable shocks for the rear, as it sways around more than I would like it too. (even with two complete D60 rear ends in the back) I am currently NOT runniong a front sway bar.
    My plans were to trim if the need came around, which it hasn't yet....
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't trade my shackle flip with stock springs and new bushings for anything. I don't know why anyone would NOT use a shackle flip unless they planned on towing.
    EDIT:
    Go 6" on the front springs.
  8. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I am running 4" Procomp lift and 36x12.50/16.5's with very minimal trimming, the only time I rub is in full flex. I can get it to rub the inner fender with the tire cut, not enought to make any noise, just enough to knock the dirt off of it. I agree with everyone else though, every rig and lift has different characteristics. mine has a 4" lift, but looks like it is actually came out closer to a 5.5" lift.
    Just my 2 cents
    Krennen
  9. clubba68
    Dec 6, 2002
    1,511
    I do have a 2000lb boat that I tow maybe 5 times a year. Need to be able to tow it safely 200 miles round trip though.
    -Andrew /forums/images/graemlins/usaflag.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I had a 4" Rancho lift and 35" BFG muds and they sure beat the hell out of my front fenders on 8" wide wheels. I'd bet on 10s they'd be worse.
  11. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Towing it safely will not be a problem, if you do it right. There are several solutions for you, that will all work great. I now tow my 5500 lb trailer/car combo with ease. It wasnt always like this, but after a good weight distributing/anti sway setup, I would not go with anything else.
    Can you tow with out it? Yes. Is it safe to? Not really. THe good part about 2000 lbs of load is that your toungue weight is relatively low. setup the angles correctly, and you should be ok.
    You can get a weight distributing hitch starting at like 200 bucks. After reading a lot of the post by guys on here with trailer problems, (and almost loosing my own truck.. twice), I now swear by these systems.
  12. clubba68
    Dec 6, 2002
    1,511
    /forums/images/graemlins/ears.gif
