Lift Height Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by roadhouse66, Apr 9, 2002.
  1. roadhouse66
    roadhouse66 Registered Member
    Dec 6, 2001
    24
    Sanford, MI
    He guys, gotta question, I'm debating on what size lift to put on my Burby, I'm considering a 4" or 6". I want to run 35's for now, but might go with 37" or 38" down the road. Should I just go for the 6" now? Also what needs to be done about steering with these lifts, just the steering arm?
    I was also considering the lift kits from 4wheel Parts, Genuine Suspensions, anyone here of these, are they decent lifts.
    For more details, my Burby is a 86, 350, 1/2ton, but I will be installng 3/4ton axles at the time of the lift. D44/14bolt combo.
    Thanks for any help.
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i have a 4" lift and 35s...to make it flex i had to cut out some fender. if you think youl be going bigger i would say to get the 6". i just put a 3" body lift on so i can run bigger tires. mods will include brake lines, steering stuf (drop pitman arm, longer drag link) and mayby more??( i only have 4") and you might need some drive line adjustments. somebody who has a 6" will prolly come on and tell you more. hope this helps
  3. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    PM chevyhs he has a sub with 6" lift and 36" tires works great or you could find him in the so cal big dawg's section in the main index!
  4. jjlaw
    jjlaw Registered Member
    Apr 1, 2002
    14
    yucaipa,CA
    I have a 6" lift on my burban running 38s was going to run 35 and if you palan on wheeling go with the 35s and 6" I bought the genuine sus. from 4 wheel parts I like it its actully procomp lift comes in procomp boxes for 400.00 out the door came with front springs rear blocks all new u-bolts and brake line extenders for front and rear 4 eleminator shocks{ thought they would be shitty but work well I'll where them out before gitting new ones and a raised sterring arm, put it all on in mydriveway in about two hours no driveline or brake mods.
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I run a 6" and a 3" w/ 38s. No hitting when I flexed it out. The fenders were trimmed by the prev owner, who had 40s w/out the body lift, but I didnt come close to hitting.
