lift help!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ross, Jul 2, 2001.
  1. Ross
    Ross Registered Member
    Apr 19, 2001
    75
    IL
    the front spring are on and i jacked up the axel to bolt it to the springs and the axel is to far back I have a 86 k5 and i think the front drive shaft is to short. Is this true or do i just have to give it a lot of muscle. what should i do, i need help. the lift is a 4" super lift - - - thanks for any help
    1986 white K5
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sounds like you could have the springs the wrong way. Try turning them so the back is at the front and vice versa.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  3. Ross
    Apr 19, 2001
    75
    IL
    i measured the midel to each end and it was the same
    sorry about the spelling
    1986 white K5
  4. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    i had the same problem with my lift. I just unbolted the drive shaft and after i was done i had a new one made
  5. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Sometimes the new springs will move the axle around from the stock position. Not to worry, just have another driveshaft made.
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You shouldn't have to lengthen the drive shaft on a four in lift. I have a 86 and did not have to. I am going to lower the t-case a little. I just haven't gotten around to it yet. I have done some wheelin with no problems......Dan
  7. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Not for a 4" lift ! It just takes a litle pulling and tugging. I had to tighten the u-bolts enough to get the axle in position, then I kicked the axle back so the sentering pin dropped in the springperch. It's not rocketscience but it will work. Maybe your frame is just sitting a litle twisted on your jackstands??
    Just get mad at it, and it will drop in place. And keep us posted.
    <font color=red><A target="_blank" HREF=http://www.espen88k5.alloffroad.com>http://www.espen88k5.alloffroad.com</A></font color=red>
  8. surg82k5
    surg82k5 1/2 ton status
    Feb 7, 2001
    416
    San Antonio,Texas
    I had ther same problem with my 4" rough country lift. The front drive shaft is an inch too short so i will get one made eventually when i have the money. i don't want a spacer cuz that means the shaft will still be stretched to the max.
    sergio
    Check out my new website. <A target="_blank" HREF=http://www.surg82k5.rockcrawler.com>http://www.surg82k5.rockcrawler.com</A>
