Lift Idea - May be silly
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hardcore, May 30, 2003.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    I was flipping through my LMC Catalog last night and noticed that on the front end of 4x4 K5's the leaf spring mount bolts on. I was thinking, why no machine a 1" thick plate and stick it between it. This would provide 1/2" of lift and help pinion angle. Or you could use 1" longer shackles and get 1" of lift.
    Anybody do this, any negatives? I'm looking at getting the ORD 1/2" longer shackles and thought a 1" spacer in the front would be better than shims.
    /forums/images/graemlins/thumb.gif
  2. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Sounds a whole lot like this:
    ORD Zero Rate
    /forums/images/graemlins/confused.gif
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    You're talking about putting something between the spring pack and the axle. I think he's suggesting lower the front spring hanger.
  4. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    I'm talking about between the front spring mount and the frame. I know that some guys lower the hanger for the rear axle. I was thinking that since the front hanger bolts in you could put in a spacer.
    Corey
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    As long as you make it sturdy, I don't see why not.
    Don't go overboard with the shackle length on the rear of the front spring, though.
    -- Mike
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The front leaf spring mount is held on with 6 rivets. 2 go into the frame, 2 go into the body mount, and 2 go into a reinforcing bracket. It looks like you could drill out the rivets,insert some type of filler in there to lower the bracket a bit, and bolt it back together. But if you play in the rocks you'll find that the front spring hanger already is sometimes the first thing to make contact, so lowering it will mean it gets beat more frequently. /forums/images/graemlins/cool.gif
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    as far as i know, the LMC cataloug shows the replacement bolts. all the K5's i have looked at, and trucks and burbans for that fact have been rivited on. unless replaced for prior reasons. i am still pondering the idea of swapping sides on my front hangers for the front springs. this would make it so i could run 52'' springs up front. but those rivets are a pain. got a few removed then decided not to. i might do it anyway.
    i could always put it back.
    grant
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah If you braced it, so it wouldnt be weak. Since its already pretty weak there, I am actually planning to take mine off altogether, get some new ones and drop them down and heavily reinforced them, that way it wont flex around and will point my pinion up. Well see how it goes.
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    Harry,
    you are right about hitting the bracket, but this is kind of a different way of thinking of it. he wouldnt be lowering the bracket. he would be lifting the frame off the bracket. so clearance remainst the same in the aspect of hitting the front hangers on rocks.
    just another view to see it in i guess.
    Grant
  10. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I sort of did that. I used a 2x3 heavy walled box tubing and some 1/4 plates and welded it together. It's bolted to the frame. The stock brackets are not even across the bottom so making spacers might be difficult. This, combined with the longer shackles added 2" of lift. I just put 52" springs in front.
  11. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    ***HIJACK*** [ QUOTE ]
    [/ QUOTE ] Any pics? Did you use the stock rear pack or did you modify it in any way? Is the ride too soft (I calculated my 52'' spring rate to be somewhere between 230-260 in/lbs... brakedive/ body roll out the goat @$$ in my book /forums/images/graemlins/ignore.gif)? How long of a shackle did you end up using? What is the total lift that the 52''s yielded? I'm looking for a measurement from the top of the axle tube to the bottom of the frame if you could be so kind /forums/images/graemlins/smile.gif.
  12. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Dito /forums/images/graemlins/ears.gif
  13. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    I actually was just thinking about doing that same thing, lowering the front spring mounts off the frame. along with the shakle & a 1" zero rate up front, if you get those front spring mounts lowered befor i do I'd like to know how it turns out
  14. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    I'm going to look into it some more. I figure I can do that and a longer shacle and get 8" with 6" springs. I figure anything I can do to get it higher and keep it flexy is good!
    Corey /forums/images/graemlins/thumb.gif
  15. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    If its done correctly, I really cant see anything wrong with it. When I talked to Greg72 about it his only concern was that now the hangers will hang down however much you lower them, which might be in the way for some people.
  16. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Not quite as easy as it seems, my friend did exactly what you are talking about and the problem is that once you get the spring hangers off, it's not a flat surface. If you ever try to do it you will see what I mean. Later
    -fLeXy K20
  17. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes i have already seen it done and thought about it. I know what you mean about the surface not being flat. Its kind of hard to explain how I will do it but ill get some pics when it does happen.
