lift in process..help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gaine7, May 15, 2001.
  1. gaine7
    gaine7 Registered Member
    Apr 5, 2001
    23
    Clemson, SC
    4" Pro-Comp suspension lift and 35" tires
    I am done with the rear end of my 79 k5 and have found that my driveshaft has fallen out and now I am doing the front just to get it done and my very front spring eye bolts are stuck. I am using Air tools and BFH, I tried heating it with a propane torch, also used almost a whole can of WD40 on the truck days ago. It seems like both sides are stuck to the frame mount. Any Suggestions??? and how about the length of the drive shafts? please help.........
    Jim
    Clemson 79 k5
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I don't know why you're having driveshaft problems with only a 4" lift. Has the truck been modded before? Have you tried using an air hammer with a flat headset to punch the bolts out? Also try using that torch to burn out the bushings if they're the problem.
  3. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    have you taken all of the pressure off of the springs?
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I agree with Jason, a 4" lift shouldn't pull the drive shaft out far enough to fall out. Torch or sawzall the bolts and be done with it.
    Derf00
    http://www.derf00.coloradok5.com
    "Four wheel drive allows you to get stuck in a more inaccessible place."
  5. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Bad luck always starts and keeps getting worse untill you take a break from what your doing.[​IMG]
    I installed a 4" Pro-comp myself a month ago and I only lifted the rear enough to get the 33" tires off. I was wondering if that would be enough, thinking I maybe needed to drop the axle more to get the blocks in there. But I am glad I dident follow through on my instincts. You will have to slide the axle back in the t-case. Mark all the positions on your drive-line and disconnect it at the rear u-joint where the axle housing is. Then slide the driveshaft into the t-case and hook the driveline back to the cross in the same position as it was.
    For the front there is a cyllinder inside the eye-bolt bushing that's rustet stuck to your bolt. If you burn out the rubber you could get more room to get the blade off a saw upp there, and cut the bolt off. Then replace the bolt with a new grade 8 bolt.
    You'l have it done eventually. Just dont get mad and bend/break something expensive.
    Good luck, hope I helped some
    [​IMG] <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  6. gaine7
    Apr 5, 2001
    23
    Clemson, SC
    Thanks guys, I got the spring eye bolt out and man... it was a pain. heated again, used PB Blaster and my neighbor came over with a bigger BFH and we used his BFH in conjunction with my impact wrench. It came loose but I definitely need new bolts...I am calling the local 4wd place to see if they have any...as for the driveshaft are you sure just sliding it back in is going to keep it in. It fell out already in the back while I was lowering the axle to get the springs in. I will try it but I think when I lower the front axle to get the new springs in I may encounter the same thing. Thanks for your help and I am glad to be almost done with my first lift..
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    You can save your time and money from the local 4wd place and get these grade 8 bolts at the local hardware store. [​IMG]
    When In Doubt, Whip It Out!
  8. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Well on what lift size do you get driveshaft problems then?
    "K5 Grand GT Blazer Silverado in the Netherlands."
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have installed 6" lifts and still had to buy that 1" driveshaft spacer from Superlift. At 6", you start to have problems there depending on your driving habits. Anything over 6" will definitely need to be lengthend or a new longer shaft built. I have never had problems with the shafts on 4" lifts.
    BTW, that Superlift 1" spacer is a cheaper method of lengthening the shafts. It costs around $45.00 and thats a lot cheaper than a new shaft. [​IMG]
  10. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    WHAT a 4 inch lift WONT pull out the drive shaft... OK... Try tellin that to me goin down hill when I hit a bump and mine popped out....
    All trucks are different...
    Just cause yours didnt need it done doesnt mean his wont...
    Be safe... spend the 130 bucks an dget it lengthened 2 inches...
    [​IMG]See me at <A target="_blank" HREF=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</A>
  11. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Hey K30... can you use that on the rear shaft? I ordered one up figuring I need to get the rear lengthen and then use the spacer on the front.
    BTW have you lowered the t-case? That should ease the length needed atleast for the rear shaft.
    1987 Chevy K5 Blazer- 350 TBI
