Lift Input NEEDED !
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KapeKodK5, Mar 25, 2001.
  1. KapeKodK5
    KapeKodK5 Registered Member
    Mar 3, 2000
    44
    I have a 4 inch Superlift Superride on my 90 Blazer. Here is my Dilemma, I want another inch or two lift. A: do I go with a front shackle lift for an extra inch or so.. or B: buy new BDS springs. I have heard good things about them but, is there really that much difference to make it worth buying a new set of springs..? I only do about 10 % offroad. I would like aa little softer ride but, flex is not too much of a concern...What do you think I need advice.. I just did a shackle flip in the rear with two inch rear spring lift..... WHat do you guys think.. there is a major difference in price like $200..my labor is no concern...
  2. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    Why not just do a 2" body lift then?
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you only want an Inch, why not the ORD 1" body lift??
    You need a softer ride? Your Superlifts Superirdes aren't soft enough? The ones I have a pretty soft iwouldn't wnat em much softer..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "Pimpin aint easy!"
  4. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I'm assuming you need the extra inch or so up front to match the total 6" of lift out back w/ the shackle flip and the 2" springs -or did you opt for the 2.5" lift shackle flip from ORD?. The only thing I'd do is go w/ ORD's heavy duty front shackles and see if that gives you enuff lift. I wouldn't use those other shckles out there that give you 1-2" lift -I've heard bad things about those kinda shckle lifts. If thats not e-nuff I'm sure you can sell your new 4" superides pretty quick and get the bigger springs from BDS. Hope that helps! -Tommy
