lift kit ? blocks or spring lift?...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Nov 30, 2000.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    i was planning or gettin a 6 inch lift for my 77 k5 and i allready have a 3 inch body lift and i was gonna put 40's on it but i dont know if u should get the skyjacker block kit or the spring lift kit ? can u please help ?....thanks
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Sounds right to me...
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yes avoid large blocks in the rear!
    Hear are the three ways I would consider:
    Do the shakel flip with a new set of 2"or3" SpringPacks
    Get 6" spring packs with no less than 8 leaves per pack.(You may need the ORD 1"block or addaleaf to level your rig out)
    Or the last way would bee to use 2"blocks and 4" Leafspring Packs.
    Keep in mind that most all springpacks are made to the weight specs of a PickUp and the K5 has a heavy butt!
    I have 4"packs in the front and 5 1/2" Superlift packs in the rear and my rig sits level.......
    Good Luck
    http://www.burt4x4.coloradok5.com
