Lift Kit brands and spring or blocks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hoss, Oct 12, 2001.
  1. Hoss
    Hoss Registered Member
    Oct 7, 2001
    41
    Seattle, WA
    I'm going to be installing a 6 to 8 inch lift kit on a 79 Blazer and have a couple questions...
    1) What are your opinions on which brand to get?
    2) Whats the advantages/disadvantages of using lift blocks in the rear VS getting new springs? I'm not worried about the cost difference.
    3) Where can I get drive lines extended (from what I read I'll have to do this with 6 to 8 inch lift). If you have specfic places in mind near Seattle, WA, great! If not, I at least need to find out where to look in the phone book for such a place.
    Thanks!
    -C
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If cost isn't a factor, I would go with springs. They may not ride as nice as blocks, but they would be safer. Especially with that much lift.
    For brands, I would look at Skyjacker and/or Superlift. Don't have any experience with either, but they are the names I have heard the most for that much lift.
    Brake lines, contact 4 Wheel Parts. I don't know if they have a place near you, but, if not, they can ship.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  3. Hoss
    Oct 7, 2001
    41
    Seattle, WA
    #3 was about the drive lines (I might be using wrong term), not brake lines.
    But thanks anyways, I needed to know that too!
    -C
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    My advice is to go springs. They definitely help control axle wrap (especially when fully loaded and/or towing). They are safer. Two disadvantages are articulation and shimming. Lift springs because of their arch do limit some articulation. Lift blocks generally come with an angle machined in them to correct for lift (but some still have to add shims), and with lift springs some people have to shim the pinion up, but I don't think it's enough to outway the positives. Ask people who have 6-8 springs and 6-8 blocks and see what was needed as far as pinion angle correction. It will give you a better idea of what you are up against. All things being equal, I would personally go for springs.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would go w/ 6" springs in front and ORD's shackle flip in the rear w/ either 2" blocks or 2.5" springs. Get the stuff from See it Here
  6. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I always recommend Skyjacker. Mine have been great.
    Friends with Superlift are not pleased. Lack of flex and bad shackle angle are some of the problems.
    Rough Country lives up to its name in my experience...Rough!
    Rear blocks aren't as bad as everyone would have you believe. I have never experienced axlewrap in the rear of my truck
    Still Poundin' "pavment" after all these years!!! [​IMG]
