Lift Kit for Diesel problem.
Discussion in '1982-Present GM Diesel' started by Radek, Jul 8, 2002.
  1. Radek
    Radek Registered Member
    Jun 22, 2002
    8
    Calgary, Alberta, Canada
    I have a 85 K5 Blazer with a 6.2L which I'm trying to suspension lift 4". I've called BDS suspension and a couple of others manufacturers and they tell me that their lift kit won't work on the Diesel as the engine is so much heavier than a gas version and their replacement front springs just won't work.
    So what's a guy to do? Can someone recommend a manufacturer/setup that will work on a Diesel?
  2. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    That's BS. What if you have a 454, factory dual batteries and HD cooling? Would weight basically as much as the 6.2 setup. Ask the manufacturers if they have a HD spring for front winch applications, the soft ride versions with tapered leafs may settle but the old stiffer square cut springs should be more than up to the task.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    contact tuff country, they sell heavy duty spring lifts......
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  5. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    I'll back the Rough country lift any day. Putting one on my 83 diesel in a month and already seen them installed. I like the ride and it holds up great to the diesel! /forums/images/icons/cool.gif
  6. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    Rough Country or Hecklethorn in Dyersburg, Tn is a great place to buy. I have a 6" lift on my '83 k5. No problems at all. They told me it might settle a bit, but I haven't seen the settle on the springs as of today and it's been on for a month. Good Prices also.
    Phillip TK5
  7. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    is the 4 inch you have an easy ride or heavy duty?
    how long have you had it on the vehicle
    thanks,
    KRUM
  8. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    It is rough countrys standard lift, I have had it on for almost 6-7 months, Have noticed no sag, and it ride fairly smooth, like a truck sould. If I had to do it it agian I would buy the same lift.
  9. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I recently installed a 4'' Tuff country HD lift on a K10 with a 6.2. It has no problems supporting the added weight, and they seem to ride better than my 6'' EZ-rides on the K5 (TBI 350). We also installed 12 1/4'' travel RSX's, hill4wheel extended shackles, ORD shackle flip and swaybar disco's, and procomp stainless brakelines. If they tell you that their stuff won't work, they don't deserve your business. My vote is with Tuff country HD springs.
  10. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    I don't think you want BDS anyway....Have you seen their prices? I got my Rough Country for 299.00, and that was with shipping.
