Lift kit in-35's on and a vibration
Discussion in 'The Garage' started by duck73, May 8, 2006.
  1. duck73
    duck73 Registered Member
    Aug 3, 2005
    5
    Chillicothe, MO
    Hello all,
    I finished my 4" lift kit Friday and got my 35's on the same day. Problem is that now I have a vibration that I had before but with the bigger tires and lift is now a bad vibration. The vibration is on acceleration only at all speeds best I can tell. I have checked the u-joints and they all checked out good. I did not put the diff lowering kit in cause several people said I would not need it with only a 4" lift. I am going to put that in but don't feel that is going to fix the vibration completely. Any suggestions?
    Also I have pics available if anyone is interested in seeing my 85 Jimmy, but I need help posting them.
    Thanks, Darren
  2. duck73
    Aug 3, 2005
    5
    Chillicothe, MO
    Help please
  3. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    do a search on here, you may need some degree shims to correct your pinion angle.
    welcome to ck5 :D
  4. duck73
    Aug 3, 2005
    5
    Chillicothe, MO
    Can't figure out how to search
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Darren, dropping your transfer case 1" and maybe a 3 degrees shim in the rear will alleviate most of your vibrations.
    Were your tires balanced? This could also be a problem.
    The search function is located in the header at the top of the web page, click on that then type what you are looking for....
  6. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    On the bar above the first post, or first topic of every page, near the right hand side, is a "SEARCH" button. It'll give you a drop down where you type what you are looking for.
    I just got done with a 4" lift, and found that I did have a bad u-joint, and maybe the pinion bearing too. I am gonna drop the t-case this week, but look again. I think if you drive it for a bit, with the vibration, you'll be able to isolate it like I did. My Jimmy drove smooth prior to lifting it.
  7. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    Hopefully you found the Search function...
    Regarding the vibes... Get a protractor and get some measurement on your driveline. That'll be the only way you can truly determine what needs to be changed.
  8. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    check the pinion shaft and those U joints I thought mine was fine but that was the problem in the end, check your angles too
  9. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    usually your needing pinion angle change and a c/v driveline - Jess
  10. duck73
    Aug 3, 2005
    5
    Chillicothe, MO
    where go i get the CV driveline. Talke with several shops around here and they know nothing about it for my model year. Said later years it was standard. Is it something I have to have made special for my vehicle or what?
  11. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
