LIft Kit Install Problem -HELP PLEaSE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Nov 19, 2000.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I Started this install of my 4 inch lift kit but I cannt get the steering arm off... It's like there is bushings in the arm attatched to the axle and I cannot get them off... I cannot remove the stock arm .... How do I get it off the three bolts...
    HELP I need it done tomorrow...
    Um... yes officer I know it's too big...
  2. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Not my normal answer, but have you tried a hammer? There may be rust or something between them. I assume you are talking about the arm on the nuckle.
    blazen91
    Protect the land FOR the people
    <font color=red>Not FROM the people</font color=red>
  3. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    heat it and beat it.......
    oh yeah, dont hit up on it, hit straight down on that bitch. seems wrong but it will help.
    matt
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>You mean the bushings under the three nuts that hold the arm on? They are a b*tch to get out! Lots of penatrating oil + BFH = out (eventualy). Just remember, they're cone shaped so hit it from the top so you dont seat them tighter</font color=blue>
  5. edeslaur
    edeslaur Registered Member
    Oct 31, 2000
    69
    Portland, Oregon
    I've had to pull mine three times - once to put the arm on, and once to move it to the new front axle.
    1. Remove the front tire on the driver's side only
    2. put the axle on a jackstand
    3. LEAVE the floorjack under the axle engaged (drop the axle down on the jackstand, then jack the jack up until it's touching the axle)
    4. remove the drag link from the arm
    4a. remove the nuts holding the steering arm to the axle.
    4b. Get out your 2.5 pound hammer
    5. Beat the hell out of your steering arm until the aluminum bushings start to pop up so you can get a bite on them with.
    I found that whacking up, then down on the end where the drag link goes seemed to work the best.
    As soon as one of those bushings pop up, grab it with a set of ViseGrips and unscrew it. The outsides end up molding to the threads which is what makes it hard to get them out.
    You can also try tapping them out (unscrewing) with a screwdriver & hammer, but that did not work for me.
    Make sure to use new bushings AND nuts with your new arm.
    Good luck,
    Eric D
    88 K30 Blazer
  6. reddog64
    Nov 9, 2000
    3,325
    So are they actually screwed in or pressed in... I need to beat the he!! out of it untill they pop part of the way up then grab and twist???
    Hope this works... I need it monday morning...
    Thanks guys...
  7. edeslaur
    Oct 31, 2000
    69
    Portland, Oregon
    When you tighten the nuts, they get pressed in and they end up seating into the threads. This is good at 85 down the highway, bad for removal. :-)
    You'll whack on it for a while before they start to budge and think I'm lying, then the arm will start to loosen and you'll start seeing the light at the end of the tunnel.
    Hit it just hard enough to barely not damage the metal (mine is a little dented). A block of wood will nullify your efforts, so wear safety glasses.
    Just make sure you put your new arm on right, 'cause it SUCKS to take these off. Easier the 2nd time, tho, 'cause you know what you're doing.
    Eric D
    88 K30 Blazer
  8. reddog64
    Nov 9, 2000
    3,325
    Is there such thing as a pitman arm puller???
  9. edeslaur
    Oct 31, 2000
    69
    Portland, Oregon
    Dunno - never checked. The parts store is about 15 minutes from here and I was sure I could pull it in under 30 (15 there, 15 back).
    E-
  10. reddog64
    Nov 9, 2000
    3,325
    PartsArmerica.Com has a pitman arm puller... think it'll work.... I'd pay the 12.99 for it... Cheaper than my time...
  11. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    we had this discussion about a day ago but oh well. The cones are just wedged in there from the top. Its like an i ice cream cone with the cone up right and around the bolt. So the largest end of the cone is on the top and the smallest part is on the bottom. I think if you know how it is in there it will help you. Anyways, i beat the hell out of mine with everything i could find and used all sorts of penetrating oils with no luck. I finally got the torch out, heated it up till it was glowing, and then wacked on the top of it really good. IT MOVED. haha Once it moved it came off easy and then i got up and jumped around like a monkey for a couple of minutes. Neighbors thought i was crazy, little did they know i worked on it for a day trying to figure it out. well hope all that helps
    Doug Krebs
  12. reddog64
    Nov 9, 2000
    3,325
    AAAGGGHHHHHH
    What about the tortion (sp) bar... how the He!! do i get it down to the spring???
  13. KrebsATM02
    Mar 21, 2000
    553
    Re: AAAGGGHHHHHH
    I don't know what your talking about. Tortion bar???? Down the spring???? be more specific and descibe it
    Doug Krebs
  14. DOUGHBOY
    DOUGHBOY Registered Member
    Oct 8, 2000
    68
    central illinois
    Re: AAAGGGHHHHHH
    those 12.99 pitman arm pullers are junk,we broke 3 of them till we decided to use a good old fashion BFH,THATS THE ONLY THING THAT WILL WORK
    guns dont kill postal workers do.
    CENTRAL ILLINOIS
  15. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Re: AAAGGGHHHHHH
    When I took mine off I used the pene oil and then whacked it hard from the side at each cone like you would do a ball joint when you do not have a pickle fork. It took a little convincing since my truck is a 74 and it had been on for nearly 20 yrs when it got changed. But it you hit it just right it will break loose and then take vise grips, grab the cone and work it out by twisting it back and forth. Your worst enemy at this point will be the accumulated mud and rust from years gone by. As for the torsion bar. I assume you are talking about you sway bar. With a four inch lift you should look into Offroad Designs sway bar correction kit. It will get the geometry back correct and will make the truck ride better as well.
  16. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Re: AAAGGGHHHHHH
    Are you talking about the sway bar? I could'nt get mine to line up either, so I removed it. I never noticed any increase in body roll, so its become a carport ornament, and my truck became 23 lbs lighter in the front.[​IMG]
    Rene
