lift kit install
Discussion in 'The Garage' started by 93h22cvc, May 27, 2006.
  1. 93h22cvc
    93h22cvc Registered Member
    May 3, 2005
    23
    milford ct
    whats up guys. i got a question. how long should it take to install a 6 inch suspension lift and a 3 inch body lift on a 88 k-5. will be using my buddys shop which has a lift. just curious. thanks for the info
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    it depends upon alot of factors, such as how much rust your vehicle has and what kinda problems you will run into. Is it a daily driver? I would give myself at the very least a week.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The suspension should not take too long with all the right tools. Some of the issues you might have to deal with are:
    -Steering arm, lots of people struggle with this. Remove it while the axle is installed to make it easier.
    -Spring eye bolts. Heat and hammer...
    -You might need to change the exhaust "y" pipe so that it does not hit the front driveshaft.
    For the BL I would start by hitting all of the bolts with PB blaster many times over since the truck is in CT
  4. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    took me a weekend. get the torches out and hack everything off that you are not going to reuse. get new bolts instead of trying to reuse some. makes it go a lot quicker. i cut the springs and everything. dont forget if your going up 6" your front shaft might not reach.
  5. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    It took me about 3 1/2 hours, with the help of a friend. I did spend extra time about a week prior making sure I had all of the right sized wrenches and sockets.
  6. 93h22cvc
    May 3, 2005
    23
    milford ct
    thanks for all th info guys . i should be doing the job tuesday providing there is an unoccupied lift at the shop i will post how i made out. thanks again
  7. DirtyJim
    May 4, 2005
    665
    San Diego
    you are going to need new tranny lines with the body lift. i put a 2" body on mine and needed to get new longer bolts for the last set under the tailpan.
  8. 93h22cvc
    May 3, 2005
    23
    milford ct
    ^thanks for the heads up
  9. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    6" lift and blazer = drive shafts.
    and go to the store now and get a can of p.b. blaster. soak all the nuts bolts and stuff till you get ready to do the kits. it will help big time. p.b. blaster is the cats a$$ :wink1:
  10. 93h22cvc
    May 3, 2005
    23
    milford ct
    ^ do i definately need new driveshafts?
  11. DirtyJim
    May 4, 2005
    665
    San Diego
    the rear will be fine if you drop the t-case. if you look at your cross member you sould have -frame - cross member - spacer - then a nut. all i did on mine was- frame - spacer - cross member - washer / nut. same drop as if you bought one. your front shaft will have to be made longer.
  12. 93h22cvc
    May 3, 2005
    23
    milford ct
    i just did the tranny and that is how i put it back together specifically for this purpose. thanks again
