Lift Kit "Instructions"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Guy, Sep 9, 2000.
  1. 79Guy
    79Guy 1/2 ton status
    Jul 8, 2000
    178
    Southeastern VA
    Lift Kit \"Instructions\"
    Hello All,
    Just bought a previously owned but unused 4" rancho lift kit, springs front and back. Besides the springs, and a couple of boxs of Ubolts and a few misc other things, there are No Directions.
    I can probably start unbolting things and figure it out -- there aren't that many parts. But I'd sure feel better if there were some directions.
    Does anyone have any directions for this, or a link to your web site where you've done the same thing? Or should I just jump in.
    Thanks,
    '79 Guy
    1 Blazer - 7 Children
    http://79guy.coloradok5.com
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: Lift Kit \"Instructions\"
    When I put my 6" lift on I put on two new axles, so it must be pretty easy to just change the springs.
    Some tips would be to not torque ANYTHING down until it's all done and sitting on all 4 tires. Cycle the suspension a few times and then torque everything down.
    Make sure you have a steering correction (steering arm, draglink, or pitman arm - just one is fine).
    Use the dropdown brackets for the brake lines (or spring for the nice braided lines) or you may pull the rubber lines in two when you articulate the axle, which would have a rather exciting effect on stopping ability.
    Your driveshaft should be fine (most are) - I wouldn't worry about them unless you have a problem.
    Your first drive in the lifted truck should be to an alignment shop for a $39 straight axle alignment (another reason IFS sucks :)
    And recheck torque on ubolts and spring bolts after 50 miles or so.
    -- Mike
  3. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Jumping in would not be bad if you are somewhat experienced tinkering with this type of thing, if you are not, might want to call Rancho on Monday and get them to fax you some instructions.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
  4. 79Guy
    Jul 8, 2000
    178
    Southeastern VA
    Thanks guys, I'll do both.
    Call for instructions, then jump right in while I wait for them to show up!
    '79 Guy
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Instructions???? I heard of those!
    creepin' and crawlin'
    Jim
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Are the rear springs 4" lift ?
    Or are they used with a block to total 4" ?
    If the rear springs are 4" lift alone you got something even Rancho does not make.
    I hope you know what you bought used !
    Good luck
  7. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    "Instructions, we don't need no stinkin' instructions"
    Jump right in, it's pretty straight forward, plus it's the best way to learn![​IMG]
    It's not what you buy, it's what you build!
  8. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Executioner,
    We have been over this and stop trying to make me look bad. My dad's company deals with Rancho directly and I have the parts book sitting right in front of me that lists that part # as a 4" rear. If it would make you drop this whole thing I would gladly fax a copy to you. I've had nothing but a hard time with you and it's getting really old.
    89 K5 Silverado
    http://mudfrog.coloradok5.com
  9. 79Guy
    Jul 8, 2000
    178
    Southeastern VA
    Hey Mudfrog,
    Just wanted to let you know I really appreciate your help w/ the lift kit. I'm just happy as a clam to get it.
    Thanks,
    '79 Guy
  10. 79Guy
    Jul 8, 2000
    178
    Southeastern VA
    \"Instructions\" What was I thinking
    Sorry Guys,
    I forgot. I know I am an embarassment to the male gender. Asking directions. What in the world was I thinking.
    I'll jump in. And, if I have any problems, I can discuss it here for advice.
    Directions! What was I thinking.
    '79 Guy
  11. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Re: \"Instructions\" What was I thinking
    Hey 79Guy... No problem with the help, just happy it's going under a K5.
    89 K5 Silverado
  12. Executioner
    Feb 22, 2000
    1,530
    How about giving me the catologe no. the page no. and the pulish, date. Both you and I have called Rancho
    and they do not make a 4" rear lift spring, sorry you just can not beleive every thing you read.
  13. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Rancho 1998 Master Catalog:
    Page 25
    It lists the part # as a 4" for 76-86, and a 2 1/2" for 87-91.
    Take a look for yourself.
    89 K5 Silverado
  14. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
