Lift kit or system?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solid454, May 19, 2000.
  1. solid454
    solid454 Registered Member
    May 4, 2000
    31
    CA, USA
    i was looking at skyjackers 4" lift and the have a kit and then a 52" and 56" system. what is the differance between these three? and how dose the skyjacker lift kit hold up to the trail master lift kit
    BIG HEAVY AND MEAN
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    The lift kit means you get new front springs and blocks to lift the rear. Or a combo of blocks and add-a-leaves. The 52 and 56 refer to the length of the leaf springs in the rear. You need to measure your old ones to be sure what you have. New rear springs are expensive and they can ride pretty stiff. And blocks also have problems like axlewrap under heavy acceleration. Why don't you think about doing an Off-Road Design shackle flip in the rear. I just ordered mine today. Go to the "search" part of this website and type in "shackle flip" It'll tell you alot. It even comes in the 4 inch lift size you want.
    '73 K5
    Chevy good...Ford bad
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    All blazers should have 52" rear springs. I would go with the new rear springs. The kit comes with rear blocks witch
    would be ok. It all depends on how much you want to spend and condition of current springs. Shackle flip is also a good idea, but if your back springs are sagging go for the new rear springs.
