Lift Kit Question
Discussion in 'The Garage' started by 84mudmachine, Mar 18, 2004.
  1. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    I have been looking a some lift kits, and noticed that a lot of them use blocks on the rear end. Why can't blocks be used on the front instead of springs? /forums/images/graemlins/thinking.gif
  2. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    They aren't safe up front. It is possible for them to pop out. /forums/images/graemlins/eek.gif Besides, new front springs should improve your ride. Always have for me.
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    you honestly dont know or you disagree that its unsafe? /forums/images/graemlins/thinking.gif
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its because you have a better chance of spitting them out on a steer axle. No one in their right mind would reccomend it. Your life is too important, and I am sure everone would agree with me /forums/images/graemlins/deal.gif
  5. bnc04
    bnc04 Guest
    I'm no expert but I would think that the lateral pressure that the front end receives when turning etc would cause the block to pop out and or the spring to flop off the side.
    The front end receives more directional force on its components than the rear which kinda follows the front along it's merry way /forums/images/graemlins/dunno.gif
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Dangerous says it all /forums/images/graemlins/shame.gif
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Personally I think blocks blow goat balls. They are unsafe for the front, so unsafe that some in states they are illeagle. I don't even like them on the rear. I would much reather use a Shackle flip like ORD's or springs, or even a combo of the two. /forums/images/graemlins/deal.gif
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    They will spit out at some point if installed in the front, this is obviously not a good thing, especially at higher speeds. They're not that great in the rear either since they promote wheel hop(which isn't a good thing /forums/images/graemlins/wink.gif).
  9. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You know it's bad if no one here is arguing about whether it is good or not /forums/images/graemlins/laugh.gif
  10. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Blocks? Blocks? Did someone say they wanted to use blocks? This isnt legos. If your going to do a lift of any kind, do it right the first time and go with either a full spring lift, or a shackle flip or something along those lines. You will be much happier with the flex and ride.
    -Harrison
