Lift kit questions...what the hell do I do?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82Jimmy, Jul 5, 2000.
  1. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    I am going to get a huge ass lift...whatever will max out my 54" texas law...what the hell does a lift do to the driveshaft and stuff? What else would I have to buy? i thought I knew what the hell was going on, until I read a bunch of posts about lift kits...
    <font color=blue>If its too loud, your too old.</font color=blue>
    <font color=red>Cameron</font color=red> <font color=green>Burnett</font color=green>
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    well longer brake lines, raised steering arm, drop down pitman or draglink, drop the transfer case or shim the axle's, bigger axle's depending on tire size. all sorts of crap!!!!!
    Doug Krebs
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Basicly the bigger the lift the farther away your diff gets from the tranny. Depending on how much lift, you could need a longer driveshaft. You also have to take the pinion angle into consideration. The u-joints will only take so much angle. This can be done with "tapered" spacers or in extreme cases, rewelded spring pads. I'm sure there are lots of guys here with more experience than me that can help with specifics.
    Michael [​IMG] http://jmartin.net/parker/goose.htm
