Lift Kit, Where and what to get?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by taterblazer, Feb 8, 2001.
  1. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Where is the best place to get a suspension lift? I'll probably mail order it. Also, any ideas how to find 3/4 ton axles cheap? Thanks!
  2. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    check out this place <A target="_blank" HREF=http://www.offroaddesign.com/>http://www.offroaddesign.com/</A>
    Stephen will take good care of all your 4x4 needs.
    See Ya,
    Keith
    [​IMG] Born to Drive My K5 [​IMG]
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I have used superlift, rancho, trailmaster, and skyjacker.
    By far the skyjacker has been the best in all catagories of:
    ride, feel, and quality of construction. the instructions were good too. I use rancho 9000s for shocks.
    As a bonus, the skyjacker is guaranteed to never sag for as long as you own the truck.
    John
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Here are a few places that are good to deal with:
    Off Road Design
    National Tire and Wheel
    Desert Rat
    Tyres International
    I really like my Superlift Superride stuf, but that is my opinion.
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I've been looking real hard at the Superlift superrides... Also have looked at the Skyjacker, but heard they ride like a box of rocks... not sure if I want it much worse then it is now. But you say the skyjacker is the best? Rides good on the street and trails? Also Emmitt you have any problems w/ the rear sagging w/ your superlift?
    1987 Chevy K5 Blazer- 350 TBI
  6. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    In my opinion Superlift superride is the way to go. I have friends that run skyjacker and pro-comp straight axle lifts that dont compare to my ride. Not rigid at all, very smooth. With my superlift, the rear rides about 1-2 inches lower than the front but that is nothing an add a leaf cant take care of. If you are going big just do your lift, then do the shackle reversal in the rear and some longer front shackles. That should even everything out.
    Later
    Have you driven OVER a Ford lately?
  7. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    what's the deal with the Superlifts riding low in the back? Do you have rear springs or blocks? I suppose running a 4" shackle flip w/ 2" springs would be the way to go, don't really want to go add-a-leaf because I don't want the extra harsh ride.
  8. My buddy installed a 4 inch rough country with front and rear springs. It sets about an inch higher in the rear- which i personally like. It articulates great and rides nice too. Plus it was only $500 bucks with shocks! Only time will tell how long it will take to sag.
  9. achuskies69
    achuskies69 1/2 ton status
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> check out the spring rate table under the technical section at the CoK5.com home page. It says Rough Country has a high spring rate which means it is stiffer and wont sag. I am going to order the 4" system they have for $295.
    00 right now. The higher the lbs/in number, the stronger the springs, but it wont have the flex of a system with a lower lbs/in system.
    just my .02
    <font color=orange> if you cant beat 'em, drive over 'em </font color=orange>
