Lift kit
Discussion in 'The Garage' started by Rhytum 4 Blu, Feb 28, 2006.
  1. Rhytum 4 Blu
    Rhytum 4 Blu Registered Member
    Oct 15, 2005
    14
    Nortern Nevada
    Need advice on lift kit.72 blazer 4" no serious off road. brands,blocks or springs any info will help decision
  2. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    cant go wrong with 4inch TC fronts and a shackle flip rear
  3. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I'm happy with my Superlift.I don't crawl rocks, don't have a gazillion hp and it's just fine with me...Just weekend wheelin' through the mud and snow.:D
  4. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I'm considering asking for this for my birth day.:bow: I'm just trying to decide if I should go with a raised steering arm, or dropped pitman arm. I've heard that the raised arm will have a bit of bump steer with only 4", but I guess I could go zero rates all around. I would also need to address drive shaft angle, but it should be close since the shackleflip actually points the pinion up (I'm just scared it may point too far up on my burb, due to the long wheel base). I still need to decide on what shocks I want to use, and which extended brake lines I need. I guess I should call ORD up one day :wink1:
    thanks,
    James
