Lift kits?
Discussion in 'OffRoad Design' started by freeforever, Mar 6, 2001.
  1. freeforever
    freeforever 1/2 ton status
    Feb 21, 2001
    305
    Missoula, MT
    Any one have any sugestions on a suspention lift? oh say a 4" thats decently priced and what ill need?
    thanks.
  2. achuskies69
    achuskies69 1/2 ton status
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> Here comes my .02 again freeforever. The kit i ordered was a Rough Country 4" lift, and it comes with shocks, brake line drop brackets(which you probably want to get longer lines), steering arm, and rear blocks for $295.00
    the kit with rear springs is 459.00 i think. Also i have heard only good things about Rough Country, so for the money this is a deal. <A target="_blank" HREF=http://www.roughcountry.com>http://www.roughcountry.com</A>
    "You call it a Honda, I call it an articulation ramp"
    <font color=green> I love cowboy hats
  3. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    You could also use the 4" shackle flip kit that Stephen offers at ORD. <A target="_blank" HREF=http://www.offroaddesign.com/>http://www.offroaddesign.com/</A>
    Then you could run the 4" TC front ez ride springs that he sells also. Put some greasable bushings in all the spring eyes and get a 4" steering arm and longer brake lines and you will be set. When you deal with Stephen at ORD you will always get great products. At least thats my opinion, any others?
    See Ya,
    Keith
    [​IMG] Born to Drive My K5 [​IMG]
  4. rich
    rich 1/2 ton status
    Apr 12, 2000
    279
    central NC
    I have the exact setup that CaliforniaK5 described, and it is great!
    ORD is fantastic to deal with!!!
    Richard
    Raleigh, NC
    '90 K-5 Blazer - stock, daily driver
    '76 K-5 Blazer - 14-bolt FF, 4.10's, locked front and rear, 36's, SM465/NP205
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    From what I have been hearing the 4" rear shackel lift, maybe 3", or 2.5", allot may depend on your rear springs !
    Also what are you going to do to the pinion angle, this may also be another veryable !
    Good luck
  6. californiak5
    Oct 25, 2000
    820
    Re: Lift kits? *DELETED* *DELETED* *DELETED*
    Post deleted by californiak5
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    since you are going a CV in the rear, are you going to drop the t-case? I have heard this hurts the front shaft's angle. I plan on going a CV in the rear as well just to avoid hassles. Thanks
    1987 Chevy K5 Blazer- 350 TBI
  8. Executioner
    Feb 22, 2000
    1,530
    "So if you use 4"
    front springs and the shackle flip you may need anywhere from 1" to 2" more in the rear to level the truck out."
    Haw, 4" springs in the front and 4" shackle flip in the rear, where is the true 4" shackle flip.
  9. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    This is a no brainer question, If you put on a 4" flip kit and 4" front lift springs your rigs going to sit just like it did before just 4" taller. So if the rear was lower before then its still going to be lower with the lift, the shackle flip moves the spring eye center down 8" from where it was which gives you 4" of lift because you only moved one end of the spring pack so you get half! So you need to look at the truck before you take it apart and go from there, if the truck sits 1" lower in the back go with 3" front springs and 4" shackle flip or 4" front springs/ flip kit/ 1" 0 rate. I think that all new springs do sit alittle higher when new but settle in probably would guess 1/2".
    RGF
  10. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    They guys above have the right idea, 4" EZrides in the front, flip in the rear. Adjust one end or the other to level it out.
    Making the world better, one truck at a time.
    SW-ORD
