lift kits
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beat'83, Feb 11, 2003.
  1. beat'83
    beat'83 Registered Member
    Sep 28, 2002
    7
    delanco, n.j. 08075
    how tough is a 3" lift on an '89 blazer to install, and what parts, other than springs and shocks, are needed?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Not familure with a 3" lift kit unless it's a body lift, So I'll assume you're talking about a 4" lift. If you buy a complete lift kit it should have everything needed. (Springs, shocks, raised steering arm, extened break lines, ...ect.) You may also need to get longer driveshafts. For the rear you have a few choices. Blocks are the cheapest way to go, and alot of people use them. I personally don't like blocks. You could go with full springs, some people don't like the ride of those though. There is also the shackle flip, little bit more work, but is nice in my opinion. There are a few things to consitter befor doing a lift. What is your goal ??? What do you plan on useing your truck to do ??? How big of tires do you want to run ??? Everything you do effects one thing or another.
  3. triger
    triger 1/2 ton status
    Jan 16, 2003
    177
    Budd Lake, New Jersey
    Hey Z3PR, when doing the shackle flip, are you to use the stock springs or would it be a good ideal to use the ford 57" springs? I already have a 4 inch suspension lift but want to do the shackle flip. I am not sure but I think the lift is basically just extended shackles on the front and rear. So definitely looking to better that. Also wondering if you have used the extended ford shock mounts? Another way I am looking to go for the front. Is that a good ideal with only a 4" lift?
    1990 /forums/images/graemlins/k5.gif
    T
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  5. triger
    Jan 16, 2003
    177
    OK i see you can use whatever u want it just makes the lift higher with the longer ones....Thanks for the clarification...I am so excited about my new project i will be starting...I like to follow you around on this board cause I always see you posting interesting and new things I appreciate your knowledge...
    T
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm no expert by any means. I've still got alot to learn myself. But I'd be happy to share what I've learned so far.
  7. triger
    Jan 16, 2003
    177
    Yeah that's understandable, but I see that you have noproblem trying to help out other peeps. I try to see who is who around here and who tries to help out all the newbies as much as they can. I have been weheeling for awhile but always drove my little bronco II. But now it is time to step up to something bigger. All and all thanks for the info and hope to here more good ideals from you and the rest of the good fellows around here.
    T
