Lift Kits
Discussion in 'The Garage' started by Jeremy_C, Jan 27, 2004.
  1. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    Depending on what brand you buy, do they come with everthing absolutly nessacary to install it? I dont mean tools, but parts. If I buy a new lift kit say a rough country, what all parts will i have to buy extra?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I think you'd be better off calling some place like ORD and have them put together a complete lift kit with every part you'll need. Most kits are missing something or another that'll hold you up.
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    rough country lifts have just about everything you wil need, unless you need to extened ur drive shafts or add shims or something, but usually people are ok, other than that it has every thing and at a really good price. they just ride rougher..but hey..its a truck! /forums/images/graemlins/peace.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Call ORD and get some Tough Country stuff.
    The list is longer than just springs, blocks, & shocks if you want to do it right.
    You need:
    Front Springs
    Rear lift (springs, blocks, and/or shackle flip)
    Shocks
    Brake lines (some kits come with some lame drop down brackets)
    Steering correction
    Then you will have to worry about what you are going to do with the driveshafts (might work...might not)
    If you only go with 2.5-4" of lift you could get away without the steering stuff and the brake lines for a while...but you will need them sometime.
    I would go with springs or shackle flip in the rear to stay away from blocks.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The complete kits that I have seen have had everything that you needed but shocks. You do pay for what you get. Some kits will come with longer brakelines and others will just come with drop brackets. Rear blocks or springs even. Just depends on how much you pay.
    If you go higher like around 6" and up. Drivelines can come into play and that can get expensive fast.
  6. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    I have rough country front springs. It rides like a lumber wagon. If this truck is your daily driver, I would stear clear of the rough counrty kit. Tough counrty is the way to go for a few bucks more.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]With the ORD shackle flip in the rear. /forums/images/graemlins/waytogo.gif
  8. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    I found an advertisement in a fourwheel@Offroad magzine for a 4inch rancho...shocks included, for bout 350-375 dont sound too bad.
  9. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    true... 350 aint bad... but how much is it worth to you to not pee blood after you drive your truck? Keeping your kidneys where they are is always a better investment than cheap stiff springs.
    I would have to agree with some of the others here, go with a pair of TC fronts and to save some $$ go with an Echobit shackle flip in the rear with a 1" Zero-rate or a 1" block (to cure the saggy butt look). your kidney's will thank you for it.
    Oh... per ORD's site, TC fronts are only $225.00 a pair... (some for sale in the for-sale forum for like $190.00) if you wanted to do blocks (not my preferred method but effective and cheap) they run between $10.00 and $30.00 in the for-sale forum.
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I just finished getting rid of my rancho. I don't even know if I will sell the springs as I would not wish that curse on anyone! I guess they would work if you had a big block 1-ton crew cab and used it only for towing...other than that they are too stiff.
    Ranchos = 720 lb/in /forums/images/graemlins/eek.gif (these were 1st gen springs)
    TC EZ-Rides = 300 lb/in /forums/images/graemlins/thumb.gif (these are 2nd gen)
    Spring rate is a HUGE thing to look into when buying a lift!!!
    If you haven't seen this you should take a look at it.
    http://coloradok5.com/springratetable.shtml
    BTW: I think TC Heavy Duty springs are still about half the stiffness of rancho (and I have heard that Rough Country is right up there with Rancho).
  11. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
