Lift options w/ POLL
Discussion in 'The Garage' started by clubba68, Dec 16, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    OK, here are my lift options that I have been stewing over forever. My rear lift is more or less settled. I am going with my Echobit shackle flip and a 1" eZero rate for a total of approx. 6.5". Now for the front, and remember that I am a college student of a VERY fixed budget, and I have tons of other things I need to purchase to finish up this lift and axle swap. I am going to have an approx 125lb bumper up front housing a MileMarker 12000lb electric winch. My rear bumper will be approx 150lbs and in addition will have a 35" tire mounted to it.
    Option 1:
    Trailmasterm 4" lift springs, with 2" extended shackles (giving 1" of extra lift), and a zero rate.
    Option 2:
    Tuff Country 6" HD lift springs up front with normal shackles.
    Option 3:
    Tuff Country 6" EZ ride lift springs with normal shackles. I talked to Stephen and he said that 6" EZ Rides do exist.
    I can pick up the TrailMaster springs for $100, and this is where the money saving comes into play. The extended shackles vs. the normal shackles are no cost difference to me. The zero rate is very minimal cost to me.
    Thanks for your input,
    Andrew /forums/images/graemlins/usaflag.gif
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Gotta watch the pinion angle with longer shackles in the front.
  3. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    6" BDSs from JDs.
    j
  4. clubba68
    Dec 6, 2002
    1,511
    6" BDSs from JDs.
    j
    Sorry, I think that I forgot to put in there that it is for a 1970 K5.
    -Andrew /forums/images/graemlins/usaflag.gif
  5. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    #3. Just because 6" will let you fit some serious tire if you want or just cruise around on 35s in style if you want. The extra weight might settle the EZ rides a bit more but like you said, zero rates aren't that big of a deal.
    And what burbboy said
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I'm a fan of BDS but you gen 1 guys are little different I guess. 6" EZ's with 1" longer shackles (1/2" lift). The 6" springs flex real nice and you might find the frame at full flex, I'm not sure on gen 1's thuogh. /forums/images/graemlins/pimp1.gif
