lift options, what should i do?
Discussion in 'The Garage' started by darkshadow, Jul 30, 2004.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    ok so i finally an really thinking about getting the old burb a 4 inch lift, and am considering three options:
    one.
    since i want to retain 3/4ton+ capabilitys, find rear springs out of a f250 ( longer i think) and swap them in the rear with a custom shackle flip by me. then take out every other leaf from the rear pack and put in in the front, with a longer shackle. I then have to buy a drop pitman arn ect.
    Two.
    buy the tuff country 4" kit w/blocks. done
    three.
    get said lift kit and chuck the blocks and flip the rear my self.
    Let me know what you think /forums/images/graemlins/deal.gif
    this is my dd and i do want to keep as much work capabitliy as posable. i also dont know the cost of a kit yet so that will factor in as expences can be a little thin here. /forums/images/graemlins/ignore.gif
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    If you want to keep towing capability, go with a spring lift all around. Either that or flip the shackle yourself and take your chances.
    John
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Option 1 will force you into trial and error to get the front height right.
    Heavy Dodge's use blocks, so blocks must be bad....
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I really like the design of the ORD Shackle Flip, it built very well, very heavy duty looking to me. And more then a few people tow with it, so, just something to think about.
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I went with 4" ez-rides up front and 4" shackle flip rear and all of the goodies they have at ORD. The ride as greatly improved over stock it flexes really well off road for an suburban /forums/images/graemlins/waytogo.gif I couldn’t be more happier with the dession I made.
  6. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    If funds are tight now, I would do the standard lift with rear blocks. Then later you can swap in rear springs or shackle flip if you feel the need.
  7. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    well i could make my own for farely cheap so....
    what did you guys pay for your kits?
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    /forums/images/graemlins/confused.gif From what I've seen the dodge CTD's are the best tow rigs out there.
    I would use an add a leaf and a block. I have been towing for years now with my K5 setup like that without a hint of a problem.
  9. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i dont tow much, but have loaded the back with tonns of stuff so. /forums/images/graemlins/peace.gif
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Go for the kit with blocks then.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Sure, if you like axle warp.
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The kit with springs and blocks.
    Big freakin deal 10 ft/lbs more then a Duramax, Give me a break! /forums/images/graemlins/smirk.gif /forums/images/graemlins/thumb.gif
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I didn't vote but here is another option for a cheap 4" lift again what I would do is flip the rear and use rears in the front. Only serious expense comes in with steering correction the rest can dang near be done for nothing if your a good parts scavenger. Just my opinion and everybody's got one so take it for what its worth.
  14. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    [/ QUOTE ]Blocks suck /forums/images/graemlins/ignore.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  15. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The F250 springs are 3" wide... could get messy.
    I think the shackle flip is good, but be prepared to address your pinion angle once you're done.
    I scooped some 5-6" blocks from a *stock* '93 Dodge w/Cummins. I didn't expect those to be in there
  16. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    A warped axle???? Never seen a block do that. /forums/images/graemlins/dunno.gif/forums/images/graemlins/histerical.gif
    If you ment axle wrap then that probably won't be an issue with a 4" block and 3/4 ton springs. I don't experience ANY axle wrap and I have had all 4 tires spinning on asphalt, towing heavy trailers, wheeling, etc. Blocks get a bad rap IMHO from taller, poor designed blocks. I wouldn't run a block taller than 6".
  17. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Bah, try putting both on the dyno, the difference will be slightly more. /forums/images/graemlins/thumb.gif It's the whole setup IMHO, D80 outback, D60 in front that is 4 linked, an nv5600 and a medium duty ISB cummins is a good combo in my book. /forums/images/graemlins/thumb.gif Especially when the cummins can handle 350 HP & 800 ft lbs all day long and still live 400,000 miles. That is unmatched by the Dmax. /forums/images/graemlins/wink.gif
  18. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Glad you never experenced axle warp, but I did with 4" block and a add-a-leaf on a 6" lift. /forums/images/graemlins/deal.gif
  19. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    How did the block warp the axle? /forums/images/graemlins/confused.gif
  20. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    there are? i am trying to think what mine are must be 2 1/2 them right? i might be abe to make that wark with a new fliped shackle ill make, and i would have to make a new spring hanger too /forums/images/graemlins/crazy.gif i dont really think i would stick to the blocks for long as i could flip it for cheap. (and i wont be cutting a hole in my hanger /forums/images/graemlins/screwy.gif)
    i might have them on till i get a little time to filp it, it would give me beter flex anyway as my ass end dont move much, want to see full drop? look to my webshots, stuck burb album,
    i think its down like 4-5 inchs max.
    i wasa trying to figgure out what the kit w/blocks would cost me? /forums/images/graemlins/dunno.gif
