lift or not lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblueblazer, Jun 19, 2001.
  1. bigblueblazer
    bigblueblazer Registered Member
    Jun 12, 2001
    21
    tampa
    which is better to raise suspension or body and how high can i raise and still be safe
    if it dont smoke,suckup gas or cost lots to fix it aint a chevy.
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Suspension lift are more expensive, but are better. The safety really depends on your driving style.....But generally, the higher you go, the wider the tires are, so they sort of cancel out, but lots of things to work out with lifts more than 4" or so.
    90K5
  3. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    90K5 is right. The higher you go, usually the wider the tire is you're putting on the truck and depends on how you drive. You'll probably get a few replies saying body lifts are not great, but a few will say they are. One person is Wes(thatK30guy), and he'll tell you that he loves body lifts! hahaha Hope he posts on here! Now, suspension lifts are the best. You can go higher and the only thing you tend to have to worry about are the driveline angles. As for the body lift, what can I say, you're pulling the body off the frame. I'm going to probably end up putting my 3" body lift on mine.
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  4. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    I have both a 4"suspention lift and a 2" body lift. I seem to wheel it pretty hard and have had no problems with the body lift.
    "Jeep Thing,? Ya i ran over one!"
