lift - pics w/tires included 3-1-07
Discussion in 'The Garage' started by AKbigsub, Feb 26, 2007.
  1. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    I spent Saturday with a friend removing my 4" lift (rear blocks and tired front springs) and installing 6"Tuff Country EZ Ride front springs (thanks ORD), rear shackle flip with cross-tied shackles (thanks DIY4x), and Zero Rates in the rear (ORD). The shocks are Skyjacker Nitro 8000's (thanks 5 Star Automotive in Anchorage). It took the two of us about eleven hours from start to finish. We had only minor problems with a couple frozen spring-eye bushing bolts. Nothing that a little cutting and and improvised press couldn't fix. I had the foresight to purchase new bolts on Friday but didn't think to get new bushings. We we able to save the bushings but I will replace them soon. We also relocated the rear shock mounts so the shocks wouldn't hit the axle tube. The only other problem was the lift block centering pins broke off in the spring purches. A little hat wrench and POW, problem solved. The front went together fine with no problems. I gained 3" in the front and 2 1/4" in the rear. It sits nice and level and is begging for the 15/38.5-16 Boggers that are coming in this week :D . Here are a few pics:
    Started with this:
    and ended with this:
    Ball-joint press used to remove seized spring-eye bolt:
    Lets cut some rivets - hearing protection was used!
    The scrap pile begins
  2. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Look ma, no bracket!
    The scap pile grows:
    Cool action shot! Prepping the axle for shock mounts:
    The scrap pile at the end:
  3. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    The end! Pics before mounting the tires.
  4. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    what you doing with the old front springs???
  5. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    I may sell them.
  6. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
  7. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    It drives a lot better! Especially since the old springs were soft and the shocks were worn out.
  8. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    Looks awsome
    I have been trying to do the almost exact same kit(ORD flip) and it has taken me three weekends. The front went on like a dream.
    I had a lot of problems with make brake lines also.
    Oh how I wish I would have known how hard it was going to be to get the new bushings in.:eek1: I am having them pressed in today.
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    That looks great. :thumb:
  10. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Thanks!
    I had a local company make the brake lines when I installed the 4" lift a couple years ago. I had them make the rubber lines eight inches longer than stock so i could go taller in the future; they used the original ends.
    As for the difficulty your having, that sucks. A routine job doesn't take too much to become non-routine. I hope you can get it done soon without any more problems.
  11. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Thanks. How 'bout your Burb? Have you repaired it after the flop? I have admired that rig since I first saw it. It takes someone with some gumption to buy a rig like that off the lot and build it like you did; it would be a shame to not have that thing on the trail!
  12. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    I purchased almost the EXACT same thing. 6" cross tied shackles, shackle flip, 6" new front shackles, and new bushings from DIY4x. 4"HD front Tuff Country springs and Zero Rates all around from ORD. New Pro Comp Gas 9000 springs and steering stabilizer from 4wheelparts. Hopefully I will be able to get it done in the next couple of weeks.
    Looks Good AK! Hope mine goes as smooth.
  13. cbbr
    Jul 17, 2004
    14,681
    Thanks for the complement. I actually got it back together and took it to Az and Nm about a month ago. Its is the perfect prom vehicle now - looks great from the passanger side.:D
  14. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    It has definately been a learning experience. I have done everything on my own. Thankfully my dad and father-in-law have lots of nice tools they let me use to make that part of it easier.
    I can't remeber who posted it(many people have), but they told me to take my time and just do it right. That is what I have been doing. It feels pretty good to say that I have done everything myself.
    I would have never had the confidence to do this on my own without all of the pics and post I have seen on here. Gotta give it up to CK5:bow:
  15. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Good job! I too have gotten some great ideas from "The Brotherhood". Welcome to the "Built, not bought" club!
  16. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Well, I got the Boggers on it tonight and boy does it look good. Y'all will have to wait until tomorrow for pics.
    I will have to upgrade the sound system to cover up the noise from these meats; man they're loud :eek: . I can't wait to get the sheetmetal cut and see how this thing flexes.
  17. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    We need pics ASAP:bow:
  18. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Here is a pic after the lift and before the boggers:
    Similar view with the boggers:
    I know that the rear end is sagging. It sat level before changing the tires. It's not too bad considering that the fuel tank is full (320 lbs), there are four ten ply tires on rims in the back (300+ lbs), and a very heavy seven foot long by ten inch tall piece of 1/4 in. steel (HEAVY) in the back.
    Different angle:
    They don't stick out as far as I thought they would (that's a good thing!)
  19. AKbigsub
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    I told my wife that I really wanted to drive it in the yard but she agreed that I had better :hack: before I do anything off the hard-pack.
  20. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    Man thoughs look awsome, congrats on all the mods:bow: :bow:
