Lift-Plow
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 91KJIMMY, Oct 27, 2000.
  1. 91KJIMMY
    91KJIMMY Registered Member
    Oct 7, 2000
    26
    I am looking at putting a plow on my old junker K5. Does anyone know if you can run a snowplow setup on a K5 With a 4 or 6" lift? Will the angle be too much?
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I have run plows on lifted trucks. You just need to raise the mounting points ont the bottom of the plow, so its more or less parallel to the ground. Some flatstock a drill and a welder is all you need. You probably will need to make the lift chain longer, and maybe the hyd lines.
