Lift problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillR, May 12, 2000.
  1. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    I'm going to be doing a lift on my '79 Blazer and I keep reading all of these posts about driveline vibrations.
    Did most of you have problems like this after a lift? I'm starting to wonder if it's going to be worth the hassle.
    I'm only planning a 4" lift using a shackle flip in the rear.
    Thanks again. [​IMG]
    Blazin' in Flagstaff
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have a 4" lift with no problems at all. I have superlift 4" HD springs up front and shackle flipped rear. Be sure to buy some 2 degree or more shims for the rear if you do the homemade shackle flip. You will need to shim the pinion down.
    <font color=red>Mudzer</font color=red>
    1978/91 K5 Blazer
